okay so i was at midway this one day, its where everyone meets up in the weekends in mn and i heard about this guy doing a straight v-tec hook up and heard that this was super kicking and was wondering if this is possible and is there any safe way to do this
Super V-tec
This topic is closed.
Originally posted by PR CB7 View Postthe reason why you've never heard about it is because
vtec super kicking is ILLEGAL
if the police find out that he's doing this, he will be arrested in the spot
the reason why super kicking is illegal, it fools the human vision in tunnel vision, making the mind think your going uber fast<a href="http://www.ilovebodykits.com">Body Kits</a>
And this "super VTEC" you speak of, I think he may have more aggressive cams, making the crossover more distinct.
Perhaps I'm wrong?
Perhaps I'm wrong?<a href="http://www.ilovebodykits.com">Body Kits</a>
just run the vtec wire straight to the battery, im sure that is what the guy was talking about - "straight vtec hookup"
has been done numerous times...
it's called vtec on-off switch bypass,
so basically you will always have vtec. as soon as you step on the gas pedal vtec kicks in hard! you don't have to wait until you reach 5000rpm
it won't damage anything, I've been running the bypass mod for a year and no problems
Originally posted by rexload View Postjust run the vtec wire straight to the battery, im sure that is what the guy was talking about - "straight vtec hookup"
No kidding? Interesting. I had no clue... so, since VTEC would always be engaged, wouldn't it also be engaged at idle?
Originally posted by jamaicancb3 View Postamm, but isnt like the same thing as using a vtec controller and setting it to 0 rpm?Originally posted by nine_deuce View PostNo kidding? Interesting. I had no clue... so, since VTEC would always be engaged, wouldn't it also be engaged at idle?
okay so im a member for mnhondas.com and was wondering if this is true:
it sounds like just wiring the solenoid on full time.
That will cause some issues (there's a reason why it's advised not to kick it on below 2k), but could be done very easily.<a href="http://www.ilovebodykits.com">Body Kits</a>
I think he's talking about hooking the solenoid to the abs system. If you can hit the brake pedal hard enough to engage the abs then dump the clutch with the gas pedal down it will force vtak to kick in hard and make your hps and torks go way up.
I have my vtak hooked up to the brake pedal to trick people behind me.
Originally posted by mj213 View PostI think he's talking about hooking the solenoid to the abs system. If you can hit the brake pedal hard enough to engage the abs then dump the clutch with the gas pedal down it will force vtak to kick in hard and make your hps and torks go way up.
I have my vtak hooked up to the brake pedal to trick people behind me.<a href="http://www.ilovebodykits.com">Body Kits</a>
