Im about to get another Cb7 and going over my options. I know i wanna stay non vtec and all motor. A H23 intake so ill use the F22 head with a A6 camshaft. A bisimoto header and fill exhaust.
Heres are my two build choices, and im interested in opinions and suggestions. Dont leave me hanging here what would you run with. Ill be running a H22 or H23 transmission.
possible build options
F22 block (85.00mm bore)
F22 head (Milled 0.010)
H22 crankshaft
F20b pistons (85.00mm bore)
F22 rod
2 layer head gasket
10.19:1 compression ratio W/ 2058.7 cc
0.055 piston-to-deck height
F23 block (86.00mm bore)
F22 crankshaft
K20 piston (86.00mm bore)
F22 rod
3 layer head gasket
10.55:1 compression ratios W/ 2207.3 cc
0.010 in piston-to-deck height
F23 crankshaft
F22 head (milled 0.010)
K20a3 piston (86.00 mm bore)
F23 rods
3 layer head gasket
11.27:1 compression ratio W/ 22.53.8 cc dis
-0.010 in piston-to-deck height
F23 block (86.00mm bpre)
H22 crankshaft
K20a2 pistons
H22 rods
3 layer head gasket
10.62:1 compression ratio W/ 2107.4 cc dis
0.035 in piston-to-deck height
I want good opinions here, im really stoked about a new CB7 to play with.
H22 crankshaft
F22 rod
2 layer head gasket
F22 crankshaft
F22 rod
3 layer head gasket
F23 crankshaft
F23 rods
3 layer head gasket
H22 crankshaft
K20a2 pistons
H22 rods
3 layer head gasket
