Plans for new 93lx build
    Im about to get another Cb7 and going over my options. I know i wanna stay non vtec and all motor. A H23 intake so ill use the F22 head with a A6 camshaft. A bisimoto header and fill exhaust.
    Heres are my two build choices, and im interested in opinions and suggestions. Dont leave me hanging here what would you run with. Ill be running a H22 or H23 transmission.
    possible build options
    F22 block (85.00mm bore)
    F22 head (Milled 0.010)
    H22 crankshaft
    F20b pistons (85.00mm bore)
    F22 rod
    2 layer head gasket
    10.19:1 compression ratio W/ 2058.7 cc
    0.055 piston-to-deck height
    F23 block (86.00mm bore)
    F22 crankshaft
    K20 piston (86.00mm bore)
    F22 rod
    3 layer head gasket
    10.55:1 compression ratios W/ 2207.3 cc
    0.010 in piston-to-deck height
    F23 crankshaft
    F22 head (milled 0.010)
    K20a3 piston (86.00 mm bore)
    F23 rods
    3 layer head gasket
    11.27:1 compression ratio W/ 22.53.8 cc dis
    -0.010 in piston-to-deck height
    F23 block (86.00mm bpre)
    H22 crankshaft
    K20a2 pistons
    H22 rods
    3 layer head gasket
    10.62:1 compression ratio W/ 2107.4 cc dis
    0.035 in piston-to-deck height
    I want good opinions here, im really stoked about a new CB7 to play with.
    Decided to go with this for a decent daily driver. Should be a interesting combo though.
    F23 block (86.00 bore)
    F23 crankshaft
    F23 pistons
    F23 rods
    F22 head (milled 0.030)
    3 layer OEM head gasket
    H23 ARP studs
    H23 intake manifold
    B16 throttle body
    H23 manual transmission
    9.90:1 compression ratio W/ 2253.8 cc dis
    0.000 piston-to-deck height
    1.45:1 Rod / stroke ratio
    of coure ill run a adjustable cam gear as well
      H22 crankshaft
      F22 rod
      2 layer head gasket
      F22 crankshaft
      F22 rod
      3 layer head gasket
      F23 crankshaft
      F23 rods
      3 layer head gasket
      H22 crankshaft
      K20a2 pistons
      H22 rods
      3 layer head gasket
      -I would not use a h22 crank. I would run as much stroke as you can in whatever block you pick.
      -F23 block has a larger main boar than f22; the cranks wont swap.
      -you should get a good cam, bisimoto level 2 comes to mind. With a stock cam, that header probably won't make good power. The stock cam does not have enough overlap to make good use of the savaging waves that header is going to produce.
      -You are going to need a tune once you do all this. When the time comes, hit me up and Ill hook you up.
      I would go with this combo. It should make some nice tourqe.
      F23 crankshaft
      F23 rods
      3 layer head gasket
      If you need a cam gear, I have a brand new aem tru time that I will sell you for $60.
      spin city
        ^^^^^Thanx man, seeing how youre in Greensboro I might have to take you up on that. Ive worked with this chassis before but mostly civics/integras(b's and D's you know) either way thanx.
        Im gonna go with this setup for now just to get it going, maybe K20a3 pistons down the road but this be alright for now.
        F23 crankshaft
        F23 pistons
        F23 rods
        H23 ARP studs
        H23 intake manifold
        B16 throttle body
