Are there any upgrades that could be done to the h22a1 using other engine parts? Kind of wish there was a sticky thread like the 30 hp for $500 but for the H22a1
H22 upgrades
I think you'd need more than 500 bucks but here goes....
Intake(obviously)
Type S, skunk2, modded h22 intake manifold
TB ported and matched to IM
"quality header" with the understanding that quality means different things/brands to different people. But the overall goal here is that you want significantly larger diameter runners than stock AND a collector that is a minimum of 2.5" followed by an exhaust that is a minimum of 2.5". Its been noted that increases can be had with 3" collectors going to full 3" exhausts.
After you've accomplished these and have been tuned you should be able to get between 15-30hp total.
After thinking about it a "quality" header alone could be your whole 500
Talk to d112crzy, I think he's pushing right at 200 with the H22 and hasn't touch the motor as far as cams, intake, etc. I would get a good header and 2.5 inch exh with a good flowing muffler as well. Depending on if you like it loud or not depends on if or how many resonators you will get.
"The Turtle"
DD/Trail Rig/Mud Bug
For $500 you won't get much. The best bang for the buck would be a wet nitrous kit though.
But since this is in the NA section, here's a small list:
-Euro R intake manifold and s2k tb
-3" exhaust
-bisi/hondata/ebay phenolic intake mani gasket
-2.5" collector mod
-3" intake
-TUNE!!!!!!!<<one of the biggest power adders on an H22
-1 step colder plugs. NGK 1283(BKR7E-11)
Free mods:
-balance shaft belt delete(just cut it)
-bypass FITV coolant lines
-IAB plate delete
