Ok I am now going to show you all what the E23 is. I am going to start from scratch this time since the original blew up months ago. I guess using cheap engine bearings was a factor. Ok I know many of you kept on asking questions about this build and what are the gains if any. This will show you an idea of what this can do. I will be using another H23 block and a completely stock f22a head. The block will use either oem honda bearings or ACL race this time around. The crank will be micropolished and balanced @ a local performance machine shop. The block will retain 87 bore probably will hone the block a bit depends. The head will be semi built. It will not have any porting or polishing done. I believe that the stock f22a head can probably flow up towards 200whp stock, so we'll see. I will either be using my existing bisi level 2 cam or the get his level 3 cam since I have seen to where his level 2 makes power up to only 6.5k rpms. It will have his springs in there as well. I am shooting for at least 200-220whp. It is plausible I have seen dynos of f22a's on bisi forums to where they used the level 2 cam for towards up to 170whp on 8.8 compression! (built head though). Last but not least compression will be @ around 11.6-12.1. This will be tuned on 93 pump gas. And redline will depends on the cam that is used. 6.7k on level 2 or 8k on level 3.
There are problems with this build such as oil passages engine mounts and etc. This will probably take a month or 2 since One of my suppliers is out on vacation and I won't get the most critical part I need until july.
This will consist of mostly all stock parts. i will be using the H23 rods with h22a1 pistons. a custom sized HG. stock oil pump or just get it worked @ endyne since only 20 minutes away. Considering kaizen speed balance delete since its all taken apart already. and blah blah blah
stay tuned!
Also Most important thing It will probably be less than 1k depending on what parts I want to use. 1.5k max.
I will have pictures as well today since I already disassembled the block yesterday.
stay tuned!
