H manifold design
    Originally posted by H22artman View Post
    what is this poormans euro-r that you refer to??
    i am poor and i have an extra h manifold in my parts box.
    something needs to be done with it.
    it take a lot of effort
    is taking the 8 holes and making 4 big rectangular runners
    d112crzy's got a pik of the manifold i did for him
    Just do what PR CB7 said.
      Sounds neat! significant gains on this poormans IM?
        great gains after 5k rpm
        remeber kids this is only on the h22-f20b-gsr's
          Originally posted by fatboy1185 View Post
          but you would think with the spacer would allow more air in, which would help?
          How would it allow more air? The manifold will hold more volume, but that's useless since it's not the manifold you're trying to fill with air.
          The less restrictions, the better. That goes with any setup, turbo or n/a.
          I have no other proof besides my butt dyno(it's accurate by -/+10whp) a tuned h22 without the spacer is faster than a tuned complete stock h22. All other mods identical.
          Here is the only picture I have of the manifold. It's the same design as Cisco's white project manifold.
            So you basically un-separate the dual runners and make it one huge runner.
            Thus you lose some interference from the air coming in. Just made it more free-flowing.
            Are you running he IAB's, plate as as spacer or nothing at all?
            and woule doing the same to the IAB plate change anything?
              I'm running no IAB plate along with that manifold design.
              It's definitely a lot more free flowing. Thanks to mr PR CB7.
                like the whole "hot dog down a hallway" expression.
                what did it take to cut into the manifold? and how long did it take?
                also, how thin are the spaces between each port? looks awfully thin to me. and did you fill in the small port holes in the middle between each larger port?
                  makes sense. I already have my h22 plenum completely gutted out, it's totally open, now i just need to start boring out the opening where the TB goes.
                  Past 1990 Accord EX Sedan
                  Past 1990 Accord LX Sedan
                  Past 1991 Accord LX Sedan
                  Past 1993 Accord LX Wagon
                  Current 1991 Accord EX Wagon
                    It's a major bitch. Just ask Oscar. I did only 1 runner because all I had was an electric dremel with some bits. He did the rest with a big grinder and cutting wheel.
                      Worth it though.
                      I am going to try this soon enough. I want to build an H22 head for track races. The track ill be going to didn't have any CB's and only two other hondas... none of us go under 15 so i have to bust me ass for that.
                      This application should be good for an n/a track car.
                        ull give up
                        ill ask a machine shop
                        if they'll do it for under 50$
                        ill save some time, money on the bill, carbide bits
                          At least it's not cast iron once you try to do a little port work on that shit you'll be glad these are all aluminum. What do you do as far as the gasket for that intake? And what about the upper part as well? Is it completely gutted to where it just open all the way or is ot just like the manifold with the skinny runner sparations?
                          "The Turtle"
                          DD/Trail Rig/Mud Bug
                            the division on the runners are razor sharp, so the plenum would be fully gutted
                              What size tb are they running wth that mani set up?
                              "The Turtle"
                                My plenum isn't completely gutted. The runners actually start at my plenum, I just made them into 4 just like on the runners.
                                I used RTV copper gasket.
                                Runnings stock tb for now. It's a HUGE restriction for my setup. It would be fine for stock h22's though.
