F20B ECU Help
    F20B ECU Help
    so i currently have an f20b bluetop with an h2b kit...on a 99 gsr tranny in my eh2 94 hatchback....nothing special just an intake and open header....now the thing is i am running on a virgin p28 ecu.....dont get me wrong its fine and pulls pretty hard just the rev limiter is around 7,400rpm-7,500rpm....cant really tell....and i know this motors is a high revving motor that red lines at 8,200.......would it make a diffrence either with a p72 gsr ecu or a jdm h22a ecu......i know most of you all will say chip your ecu and tune it....but right now xmas is around and all...dont have much cash....what do you all recomend me to do......i know they all run diffrent maps...just need a little more knowledge....which ecu should i be using for now?
    cb7 A NEW ERA
    a h22 ecu (p13)would be better than a virgin p28 and a p72.
    considering a f20b blue top is just a destroked h22.
    FS: DSM turbo parts,OEM parts, and more.....
    My Members Ride Thread - R.i.P
      any more opinions?
      cb7 A NEW ERA
        Get off that virgin P28 ASAP its made to run a 1.6L with tiny injectors, it would cost you pretty much the same for either a chipped p28 as it would for a p13, but with the p28 you can tune it for your engine, and injector size, right now it may seem like you have alot of power but your running lean also, or you could just buy a chipping kit and have someone chip it unless its your DD, and you cant afford to not have the car for a week or so, also did your stock intake piping fit right onto the TB or was it too small?, you:ll want to make sure you do have the 200hp sir-t version and not the 180hp sir version which only redlines at 7800
        PSN ID's:Tidashoni
        1992 Accord EX Coupe
        My FS Thread
        Not so DD 2013 Subaru Impreza WRX STI
        Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
          I have a map you could try out. f20b with bolt on's and h22 injectors.
          Past 1990 Accord EX Sedan
          Past 1990 Accord LX Sedan
          Past 1991 Accord LX Sedan
          Past 1993 Accord LX Wagon
          Current 1991 Accord EX Wagon
            yes i do have the sir-t version....how about riding a p13 ecu?
            cb7 A NEW ERA
              You'll have to wire in a knock sensor if you use a p13.
              Since you have p28, you could send it to me to have chipped and I could send it off with a basemap for you.
                I agree with above. bolt ons with p13 ecu and h22 injectors.
