![](http://i22.photobucket.com/albums/b340/heyitspete790/081.jpg)
I'm starting to put together a list of parts needed.
port and polished f22ax head
exedy OEM replacement clutch
f1 racing 11.5 lb flywheel
bisimoto level 2 cam regrind
bisimoto intake manifold gasket
bisimoto pro springs
ARP h23 head studs
blacktrax intake manifold spacer
maxbore h23 plenum & throttle body - purchased
air boost valve block off plate
AEM wideband o2 sensor
chipped p06 ecu
this build is not to make stupid horsepower, but to keep the reliability of the f22 and run a little track time. I still need to look into the crankshaft and bearings, and what type of head gasket to use. I'm not sure how to measure or even what to measure for that matter on both the bearings and headgasket, so this will be a great learning experience for me.
am I missing anything? is something on the list that really doesn't belong there?
