P72 on stock F22?
    P72 on stock F22?
    will the P72 work on the stock F22a1 motor? if it does is it just basiclly a plug and play?
    i feel stupid for asking this!
    Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
    rock her with the shocker!
    P72 won't do anything for your application, if it runs your car at all.
    Btw, there is NO selling outside of the classifieds.
      p72 is out of a gsr if im not mistaken and its progrmmed with vtec and iabs which your motor has none so answer is no, get an h22 chip the p72 and burn a h22 base map and tune it then it will be plug and play
        i know there is no selling here i was just asking how much?
          Look on ebay, or in the classifieds... Don't ask how much people are selling things for here. That would be the beginning of a transaction, and that would result in you and other valued members being banned from this site. We take this very seriously.
          Any ECU that isn't designed for your engine will not work properly. ESPECIALLY an ECU that's designed for a 1.8L VTEC engine. Will it run your F22? Probably... but it may do damage as well.
          To use any ECU other than a PT3, PT6, or P12 (all designed for the F22A engines), you'll need to chip and tune... something that costs a good deal of money to have done, and something that takes a lot of knowledge and tools to do properly.
          On a stock or near-stock F22A, there's no real benefit to even touching the ECU. Tossing in a P12 on an F22A1, or a PT6 and the F22A6 parts to make an F22A1 into an A6 are the only worthwhile things you can do. The MINIMUM mods that you should have done when considering a custom ECU would be intake, header, exhaust, and a camshaft upgrade... if you don't at least have that much, there's no point.
            sorry i was just curious.... my bad
