H23 Delta 272 camshaft issues
    Yeah, compare stock h23 vs stock f22b IN the head and see how close they come to binding.
      all I can do is slide a feeler gage between the coils, and once the gap gets so big that becomes a lot harder to do. Ill do this tomorrow.
      spin city
        f22b and h23 cams have the exact same lift. even with the new head, the springs bind. I'm going to mill the head as much as I can, send my cams to delta to have them grind a bit off the top of the lobe to give it less lift. I'm thinking that something like a 425 lift would be good and reliable on stock springs. I'm replacing all my valve seals, and even though I don't wanna spend any money on this head that I don't have to, I'm going to get a valve job. I'm not satisfied with the lapping or I have some bent valves. . Ill be running this head for a while, so I'm going to make sure it will last. stock cams are going back in for a while so I can get it running again
        spin city
          This is a weird situation. I don't understand why others have never had problems
            perhaps they never paid attention? I almost missed it.
            spin city
              I took the head to a machinist today, he is going to get it running condition so I run my car again. stock cams are going in. I'm thinking about a 262 regrind since I would like to boost when I can afford to do so. I'm going to call tomorrow to find out what the specs on this cam are.
              spin city
                when taxes get here, Ill be getting some bisimoto custom valve springs, so I will be running this cam soon.
                spin city
                  This is unbelievable. this motor must still have bent/ leaky valves!!!!!!!!!!! I didn't double check the head for leaks before I put it on because I trusted him, and I was eager to get it running again! I was very, very careful and there is no way I bent the valves after I got the head back. I stayed up all night last night getting this car back together just to run a compression test after class and find that I have leakage still!!!! I should have double checked his work at his shop. now I have wasted near $200 on this head to get it running and I'm still in the same place. Well now I'm gonna go tear it back down, AGAIN!
                  spin city
                    Do a leakdown test before you teardown, not a compression test. As you get more aggressive with your camshaft it affects valve timing and will affect a compression test.
                    Again, leakdown test and if you hear air rushing out your TB plate when open or exhaust tip, then I would suspect bent valves or bad valve job.
                      Did you ever try to install stock H23 or JDM F22B cams on your new head? If so, what were the results, any coil bindage?
                        ok so I took the head off. now I have bent intake and exhaust valves, ecept for the number 1 cylinder. I am 100% sure that I installed everything correct, I double checked my cam alignment when I dissembled everything and it was good. I spent a lot of time and I was very careful when I put the motor back together. what I wanna know is how this guy could mess up my head this bad? His prices were pretty cheep, ($90 to have the heads shaved, valve guides installed and a valve job on the exhaust), but he seemed like a good guy so I went with him anyway. I guess you get what you pay for.
                        spin city
                          no coil bindage with stock cams, which is what I was gonna run (and I had in there), untill I got bisi's valve springs. btw, I'm getting quick at getting that head off, lol.
                          spin city
                            I guess you need a reputable shop then.
                              I'm going to take the h23 head back there, and see if they will fix it. I'm not letting them touch my f22b head. if it gets fixed with no leaks I will run it. If my taxes come in real soon, I might just rebuild my f22b head and sell the h23 head.
                              spin city
                                Tell them to vacuum test the head after they do whatever work needed (i.e. replacing valves and valve job).
