fuel management for boost
    ok. i was looking and searching and reading. now i have a question:
    the auto on boost is no out because its getting sold now i have the 5spd left. can i use my stock injectors if im running like between 5-8psi? or do i have to switch to a injector that has a higher flow rate? alsoo what fuel pump can i get that that would be good for boost? i hear the walboro is pretty common.
    as for fuel pump not sure.
    But you are going to need to upgrade the injectors.
    "Auto racing, bull fighting and mountain climbing are the only real sports....all others are games."
    - Ernest Hemingway
      well...
      it all depends sounds like your using the basic f22 setup correct? what size turbo?
      myself am going with my f22a1 stock engine with a 14b turbo.
      Here is my fuel pump I plan on buying, plenty sufficient for the goals I am trying to meet.
      http://www.xenocron.com/catalog/xeno...ump-p-148.html
      Good luck!
      MadLab Racing
      Southern Maryland
        Good luck!
        well im going to be using a t3/t4 turbo. nothing big. i want somethign will spool up quick but not too fast as to give me nothing up top. any other recommendations for turbo sizes?
          would the DSM injectors be good? can i use some H22 or H23 injectors or do they both(H22 and H23) have the same flow rate?
            at a minimum you need dsm injectors, 450cc. a walbro pump is cheap insurance. get a P06, tune is with crome, and go have fun.
            instagram @mikeymeyagi
              You can push stock injectors on a forced induction setup to about 160whp(you can go further with NA).
              What are your power goals? If it's anything under 220whp, you can get away with 390cc injectors, which I have for sale .
              But really, most people do 450cc injectors to have a safe margin. I'd recommend those as well.
              drummersteve showed you what pump to get, get it.
              As for turbo sizing, you need to look more into it. saying t3/t4 is too vague because there are tons of different sized t3/t4's.
              A good turbo that will go up to 400whp if you'd like but still be efficient on low boost would be a t3/t4 57 trim with either a .48 or .63 turbine. The .63 will spool slightly later than the .48. I'd go with the .63.
              http://blaastperformance.com/index.php?p=t3t04e-57
              Do a search next time. ALL your questions have been answered numerous times.
                im also boosting my car
                got a 14b turbo and using 450cc injectors...gota buy a 255 fuel pump too
                Hold On Not Done Accelerating
                Had One Never Did Again
                  all you need is bigger injectors, an s-afc, and a fpr... forget chipped ECUs, you don't need 'em!
                  right d112?...
                  J/k
                  THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
                  My Ride thread
                  Flickr
                  Originally posted by d112crzy
                  And it can only get better. That's the best part.
                  All I gotta really say is:
                  People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
                    FMU and check valves will do the trick.
                      dont use an fmu they are worthless and cause more problems than help. 550cc injectors and a safc is all you need. your oem fuel pump will work fine. thats all i had on my car and i ran 300 hp for a very long time.
                      member ride thread
                      DIVULGE MOTORSPORTS
                        told ya!
                        My Ride thread
                        Flickr
