Who says the stock block can't do 20psi. HA!
    build some suspension limiters.
    they'll help tremendously.
      Some who what's? I forgot to mention I also have the 2nd batch of the Collective Racing traction bars, but after it broke, I fixed it so it's stronger.
      wat
        suspension limiters, look it up.
        you'll get rid of all dipping your car does at launch.
        should get you under 2.0 60's
          Before the new turbo setup, we had no problem getting consistent 1.8 60fts, so I just suck at driving with this setup. More practice this weekend if the track opens, I'm aiming to please.
          wat
            1.8 with the slicks or without?
            thats good. either way.
            I've never been able to get under a 2.2
              That's with slicks, on the smaller turbo setup.
              wat
                I'm a little confused...you said you boost spiked to 20 and the engine blew...but you're posting 400hp numbers at 20 psi, I'm not seeing what psi you ran normally.
                Did you run 20psi on this engine for a while? What caused the blow?
                ____
                  Why/how do you feel the slicks gave you the problems?
                  Too big?
                    damn how did i miss this thread, crazy number. how many miles on this setup?
                      have you tried a traction bar setup at all? Good numbers and soon you'll be hitting 12's
                      SOLD!!
                      Boosted H22
                      375whp 298 ft/lbs at 15psi
                        The engine blew up a long time ago and I put it back together on a stupid cheap budget because I had the Subaru. Also, the boost didn't so much spike this time as it did creep, but we were tuning for that on the dyno. So instead of an untuned 20psi spike, it's a tuned 20psi creep. Now that my wastegate situation is resolved, we're going to retune for mid-range and hopefully have this thing be an overall monster!
                        Too big?
                        Traction issues overall. I need to adjust the suspension a bit more to get the best combination. I didn't have any opportunities last time at the track because of the track conditions.
                        It's not a daily driver, so not a lot of street miles, but it has probably 10 drag passes under its belt and probably equal amount of dyno pulls.
                        Yea, I have a traction bar. And 12's shouldn't be hard, 11's should be close to follow. I just have to learn how to drive. Ha!
                        wat
                          Originally posted by F20A CB7
                          and so is runnin 110 octane. That alone gave him the power
                          lol
                          This car is silly........your torque figures are extremely impressive, and your powerband is fiiiilthy.
                          Totally
                          14 Ford Focus ST - stock(ish) - E30 Tune + Green Filter =
                            What spark plugs are you running?
                              yes, please answer
                              Formerly 91AccordExR33
                              11.68 @ 127mph
                              417whp/375wtq
                              Sold: 8/2016
                                Originally posted by verothacamaro
                                lol
                                Totally
                                Thanks, it needs to be tuned for the powerband, but we'll see what turns out this Spring.
                                I'm using NGK 8-series plugs, unsure of the part number, gapped .020.
                                wat
