Im wanting to do a mild build on my h22 to run a little more boost than I am running now(5-6psi) and to make a little more power a little more safely. What I came up with as far as the budget Im on is using a forged rod on an h23 piston to lower compression a little and strengthen the rotating assembly. My question is, is it possible to use a stock style piston on a tuner toys forged rod which is floating wrist pin style http://tunertoys.zoovy.com/product/R...ting_Rods.html
I figure what may have to be done is that the rod may have to be machined out a bit to allow for the press in wrist pin style, but I don't know if im heading in the right direction as far as that goes. Also Im wondering how much of a benefit this would be, I plan to run around 15psi and hopefully make close to 350whp. Any input on this is much appricated.
