Will this simple setup work for now with stock injectors and an apexi neo? to start I will be running 4psi so I can be done and go to school and what not since school is starting up kinda soon. Afterward I have springs for 6,8, and I think 10, but then I will need injectors and a map sensor. But will an afc work for now?
4psi+stock injectors+afc neo???
you do know the wastegate controls boost so you would need one that can do so, but theres very few, if any, that can do that"You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
Use a spring from a carb. Tension it as much as you want, or as little as you want. There's your damn wastegate.
An AFC is fine. Even with higher boost pressures, an AFC will do just fine.
You just won't have anywhere near the power you should have.
Save up and do it right, once.
Originally posted by d112crzyUse a spring from a carb. Tension it as much as you want, or as little as you want. There's your damn wastegate.
Originally posted by F22HBok, thats kinda what I needed to know, but how about injectors? They're fine for low boost right?
Those injectors would be a gamble, if nothing else im sure obd1 h22 injectors would be sufficient at 4psi. Honda map sensors are good to right around 11-12 psi. The only thing that will be holding you back is the afc, while it can be done safely, its still more risky than a chipped ecu on chrome, uberdata, ect...H22-T FTW!!!
dont do it with stock injectors just get some cheap dsm injectors on http://www.dsmsource.com/classifieds/index.php
450cc injectors afc your def good for 4 psi if not more maybe 6-7 psi
Yeah, spring for some DSM injectors. The AFC hack tricks the map sensor, that's why it's a hack. Get some injectors, and wideband tune it for 6-7psi. In case you didn't know you'll actually have to pull fuel with the larger injectors. If it's tuned this setup should be totally safe, although not as powerful as a properly managed setup (which is why i recommend 6-7psi instead of 4) good luckH.S.A.E.
90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
wats an AFC , me=NEWBII yet**Blk Housed Slut Crew Member #1**
1 extra PSI per Cylinder would not stress the car out to the point that the injectors fry and the map sensor implodes. Make sure that there is no kind of boost spike that way the HACK wont blow you car up. Well Id just make sure I would Boost spike. And Keep it cold. An intercooler is not needed until about 6-8 psi. BOV is need for sure so that there is no shock to the T/B. Injector upgrade for the 4 psi is not needed honestly. Id def HACK if I could untill some one or your self could ECU TUNE
