DSM Turbo Manifold on an H22?
    I'm not a fan of the whole junkyard turbo configuration but this just came to mind. It does work on the F22Ax and JDM F22B DOHC non-Vtec but how about the H22A? Anyone ever look into it?
    I was going to hit the junkyards this weekend and see if I can hunt one down. I've got a T25 off an Eclipse just sitting at home so it got me wondering on the manifold.
    Anyone with experiance here I'm looking for enlightenment
    Re: Re: DSM Turbo Manifold on an H22?
    Originally posted by fizzbob7
    damn dude you're cheap
    but since the f22a's pattern is slightly different, i didn't think it would work...even on the f22a's you have to mod it a little bit so the holes line up i think....the port location/pattern is the same, but the h is different.....i'm sure you could find a used h22a turbo manifold for not too much.....you're like me....junkyarding is just fun
    I just love it when you get garbage from the junkyard and make it work again.
    How different is the H's exhaust ports then the F's? I know you can use the H23A's exhaust manifold on an F22A1/4/6 so then the difference must be between the H22A and H23A?
      quick question...
      is there any advantage to installing a H23 header onto an F22Ax engine?
      sorry, but ya had me thinking for my F22A1 buildup
        yea it wont work the f22a1/4/6 and h23 and jdm f22b port are like oooo but h22 is o oo o. so the ports dont match with the dsm's. and yea for putting the manifold on the f series you only need to redrill the bolt holes, the ports line right up.
        HSHO #3
          That's what I've heard about the 0 0 0 0 and 0 00 0 port configurations. The F22B1 is really 0 00 0 but the H22A doesn't look like cylinder 2 and 3 are that close together but maybe they are. They look more 0 0 0 0 to me.
            Originally posted by HondaFan81
            quick question...
            The collectors are larger so people doing allot of head work and intake work for example a large nitrous shot engine would benefit from the larger collectors but on an engine with no real work will actually end up hurting the power band.
