hey what motor mount can i use for the front i have a h23 with a big 16g
tubo motor mount
as far as custom, i used the 2 AC compressor studs to adapt my front mount too...although i'm not sure how good it is.
hard to explain, but i cut the round part off the front mount, then welded the bracket that goes on the engine to the cross member. From there i just welded the round mount to a plate that bolts to the 2 studs.
seems like it must help...when i geometrically figured out the torque direction of the motor i placed it with the best angle....i'll have to get some pictures up.
Mark
Buy one of them lile dampener mount things those help out and poly the rest of your mounts so its stiffer. Works wonders.
Originally posted by mtnickelas far as custom, i used the 2 AC compressor studs to adapt my front mount too...although i'm not sure how good it is.
Mark
id like to see those pics
Yea Evans Tuning is basically FUll Race. They do a lot of good work. Pretty pricey but high quality. As for the wastegate setting 8psi is my guess but someone else should know.
