What do you rev to with your boosted accord?
    you'll be fine using either one you choose.
    keep timing safe and you'll be fine.
      Sorry for bringing this back from the dead, but i have changed my setup a bit, mostly the cam. I am now running the delta 262 cam, fully built head and block just stock sleeves and crank. Before i said i was gonna hit 8000 rpm, but this is a daily driver and reliability is important to me. I am now wondering if 6600rpm pretty much every day and 7000rpm on special occassions is safe on this setup?
      I know d112crzy said ill be fine but this was with the 282 cam. I know i have to see where power is made on a dyno, but my tuner is doing a full street tune first (dyno later in the year) and i *think* that 6600-7000 rpm is still in the efficiency (sp) range of the turbo/cam. Im mostly concerned if its safe or not for our F22 SOHC motors, specifically the piston speed with the 95mm stroke...
      1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
      Member's Ride Page | Video of my CB7, Open Downpipe peelout
        my motor is on rev limit at 7600rpm, like flailing of rev limit burning the tires off, just about every time i drive the car. its been taking it for over a year with no adverse affects i can see. use good oil (read royal purple or amsoil)
        instagram @mikeymeyagi
          A 260 regrind is nothing to be worried about. I doubt you'll make it past 7k with it.
          It's not the piston speed you should be worried about, it's the force put on the pistons/rods/bearings. But since you've upgraded everything, you'll be fine.
            Cool, thanks guys
