compression
    compression
    95 honda accord test came out 175,175,175,185
    does that mean the ringlands are good or the cylinder can hold good amount of air?
    so that man its good for turbo but i can still be burning oil or what?
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    your good for boost.. sounds like you have carbon build up tho... after you boost for a bit.. do a compression check again... i believe factory specs are 178psi
    HAN - ZiviCase10287
    Honda-tech - zivicase
    HMT - draztik
    d-series - draztik
    Team Integra - RacinMasonC
      carbon build up what you mean by that?? how long is the compression test results good for?
      i do have black smoke my my tailpipe only tailpipe not on back bumper i believe its because i was running with a bad o2 sensor don't know..
        It means what it sounds like, carbon built up in the chambers. Carbon is a byproduct of combustion.
        Looks like this basically
        1993 Prelude S
        F22A1
        custom'ish turbo setup
        180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
        18psi boost spike = BOOM!!!!!
        currently being rebuilt
          okay see what i don't get is why am i getting higher rating if its carbon.. i thought the higher the number is the better the rings are holding up? help me out thanks.. if i clean it with fuel system cleaner will it clean it right out or what.. need help serious.. but i can still boost safely right?
            carbon build up takes up a small amount of space in your combustion chamber, on top of the pistons and valves and even the rings and ringlands. Basically its keeping your compression high in the cylinders esp the one with the most compression! But it isnt really a great harm to an old engine. Boost it!
            WaC!
