Hi there,
So upon a little more research (after who knows how many hours)...i found possibly an OK piston/rod combination.
Ok, so the Eclipse 2nd gen 4g63 piston with 4g64 crank (stroker combo for 2.3L), is very close to what we need to pair with the H22 rod.
specs.
Weisco K596M85 (also available in 85.5 and 86)
$439 85.00mm bore
Compression height 1.130
Dome -21cc
Pin bore .866in
So pin bore lines up, but it has a lower compression height (actually sits inside the cylinder.
Our Compression height is 1.201. that leaves .071" in the hole.
However, the H22 rod is .061" longer than ours..so using the h22 rod on this piston will give only .01" negative piston/deck height which is not bad at all. So it just sits inside the cylinder ever so slightly.
ok...now with the 21cc dish (a lot more than our stock dish)...we're gonna have a lower compression ratio...as calculated is 8.03:1. Not bad at all for high boost applications.
Anyways, only thing i need to still find out is if valve angles and recesses will work out.
Otherwise we could have a nice combo here for $439 and about $220 for Eagle H22's.
What do you guys think?
Mark
specs.
$439 85.00mm bore
Dome -21cc
Pin bore .866in
Mark
