looking for F22/ DSM basemap
    As the title says im looking for a basemap. Im throwing in the turbo tomorrow and want something decent to start it up on thanks, hit me up on AIM or MSN, PM anything.
    14b turbo
    450cc
    contact mrx, he should have one.
    I lost all my maps not b/c i had to reformat
      i've got the 14b basemap...although if you care about your engine it's probably best to have it professionally tuned before you start beating on it. Just my 2 cents...especially after blowing 2 engines (boost creep 1, and lack of tuning on DOHC 2). hehe
      Mark
        Mark
        I just need something better than stock, My shop is about 3 hours away, I need something to get me there. If you dont mind sending it my way (tennis160@hotmail.com)
          disconnect throttle body charge pipe, put stock injectors in, use stock ecu to get there. When you get to the shop, reconnect pipe, slap the injectors back in, and put in the chipped ecu. most logical and safest way to do it
          Shift_BOOST
          BOOM!
            Either all that, or take the cotter pin out of the wastegate lever and let the lever run free...you may build like 2psi by redline, but nothing dangerous on that map...then you have an air filter too (provided you have some sort of filter on the turbo which is highly recommended).
            Mark
              but dont rev high, because it will own your turbo! I should know lol!
              emailed ya!
              WaC!
                Thanks guys for the e-mails I really appreciate it
