turbo vacum lines
    turbo vacum lines
    ok so i want to make sure if this is how its set up:
    the bov goes to the fpr with a T conection right...
    and the wastegate goes to the the nipple in the intake manifold on top of the TB closest to the firewall...
    and the boost gauge goes to another T in the fpr...
    Upgrade your mind before you upgrade your car
    "So. Cal OUTLAWZ "
    bump for my double checking
    "So. Cal OUTLAWZ "
      yep you are right except the boost gauge can go on any vacuum source
        with my wastegate line i have a line running right off the turbo compressor outlet i think the closer you have the line the better the response will be from your wastegate.
          the problem is that i dont know where to run the wastegate on my car... my manifold f22b2 is a lil different than the f22a1 and it doesnt have the nipples on the TB
          "So. Cal OUTLAWZ "
            use the vacuum line that goes from the tb/IM to your intake when it was NA
              thats the thing on my IM it doesnt have a vacuum line...
              "So. Cal OUTLAWZ "
                take a picture i guarantee you have atleast one unused vac line... check right above the throttle body there should be three or four.
                1993 CB7
                2001 BB6
                  all you need is a spare vacuum line before you had your turbo when you had a vacum line going from your intake to your manifold thats the one you use
                    i took some pics here they are
                    this is my Throttle body it has no vacuum lines:
                    http://i2.photobucket.com/albums/y38...r/CIMG1533.jpg
                    and this is the opposite side of the Intake manifold, this is where my manifold has all the vacuum lines, i circled in yellow a vacum line that is blocked off... is that where i should run it???
                    http://i2.photobucket.com/albums/y38...r/CIMG1534.jpg
                    closer view:
                    http://i2.photobucket.com/albums/y38...r/CIMG1535.jpg
                    "So. Cal OUTLAWZ "
                      yeah any vacuum source should work might want 2 double check on that but im almost 100%
                        is the source that i circled in yellow in the pictures an alright source to run the wastegate vacuum
                        "So. Cal OUTLAWZ "
                          you want your wastegate vacuum source as close the the compressor as possible, for safety. the further from the compressor, the more "spike" you will get.
                          but aside from that. it doesnt matter what vacuum source you use. its a closed system, there all the same
                            with my 16g and F22B dohc head...when i ran the wastegate line right off the compressor outlet i got some 2psi of pressure drop in the top end. Mostly due to either my intercooler, or 2" charge piping. running it at the TB assures you hold your exact boost to redline even with pressure drop, but as stated it will give you a little spike.
                            The spike is quite minimal on my setup though (barely 1psi)
                              please excuse my stupidity but u guys are talking about the turbo compressor right???
                              "So. Cal OUTLAWZ "
