My Comprssion Test Results!! There awesome!! lololol :)
    Cyl. 1- 25
    Cyl. 2- 75
    Cyl. 3- 70
    Cyl. 4- 60
    So that means that cyl. 2,3 and 4 are ok because there withing 10-20% of each other right
    L8r all, thought some of you would like to know (Or have a good laugh at) the results.
    Turbo H23a3 build has begun
    01-01-2019
    Originally posted by bjaccord
    Cyl. 1- 25
    Cyl. 2- 75
    Cyl. 3- 70
    Cyl. 4- 60
    L8r all, thought some of you would like to know the results.
    wow... what happened? holy boost spike of death?
    1993 CB7
    2001 BB6
      I don't think it was a boost spike, I've had a few, and the motor surprisingly took them very well. I had one spike (My vaccuum line fitting backed out of the wastegate somehow) and hit over 20 psi (My guage only goes to 20, so who really knows). I know my wastegate was open on this run, and I glanced over while in 3rd gear and it was at 9psi, so I'm don't think there was any kind of spike.
      Before I did the test I figured ringlands for sure, but now I'm thinking the head may have lifted. The odds of wiping out all 4 pistons, or having the headgasket go in a bunch of different places is slim to none.
      I ordered new head studs today (ARP) and will be taking the head off to see what it all looks like, and if that the case, and it can be fixed, I may be up and running within a few weeks.
      Honestly though, I doubt I'd be that lucky.
      L8r
      01-01-2019
        i was gonna say... you dont usually see that low of compression on all 4 cylinders like that... my only guess is the head as well... if that was the case wouldnt you have blown h/g symptoms in the crank case from coolant-oil contact? either way, hope it ends up being an easy fix man... dont you have that spare h23 you started cleaning sitting around by the way?
        1993 CB7
        2001 BB6
          I couldn't find any oil/coolant mixture in either the pan or radiator, but I also shut the engine down very quickly, so it didn't have much time to mix.
          And the spare h23 is my build motor, which has atleast two months left, if not more before completion. If mine truly is crap, then the car will simply be parked until Feb/March.
          Either way, the arp headstuds will get used, so I figured I might as well order them up.
          L8r
          01-01-2019
            Wow, I'd say uh...you've got low compression, haha!
            wat
              Sure beats my 175 psi across all 4 cylinders after 237,000 miles
                man resurfarce the head get a new hg and some arp's and slap that bitch back on.you might just get lucky.
                ILBB
                People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
                Mk3 Supra Member #2
                Originally posted by DarkShadow707
                The world needs to be reset.
                  The stock head won't be going back on......
                  L8r
                  01-01-2019
                    called it
                    1993 CB7
                    2001 BB6
                      What'd you wipe out?
                      wat
                        This is a spare head that I've been working on for a while. I'm actualy going out right now to work on my car. I may get the head off today, not sure yet.
                        I'll try and post up tonight if find anything. L8r
                        01-01-2019
                          Well....
                          Cyl. 1-Melted
                          Cyl. 2-Not sure, cracked ringlands?
                          Cyl. 3-Not sure, cracked ringlands?
                          Cyl. 4-Melted
                          Headgasket-Just fine
                          Cyl. 1 is pretty bad, and 4 is barely noticeable.
                          My guess is that when cylinder 2 and 3 were compressed from both sides the ringlands cracked.
                          Let the parts ordering commence.
                          I forgot my camera so no pics, but its nothing great to look at, just some out of round pistons.
                          L8r all
                          01-01-2019
                            Catastrophic, that's pretty tight...
                            wat
                              i hope it wasn't that torque curve...i was very weary of it when u showed me your dyno graph
