maximum psi on unbuilt f22a6
    a friend asked me what is the most psi you can put on the f22a6 in good condition without destroying your engine or rebuilding the bottom end
    im guessing 12 psi .... and have it running as an everyday driver...
    the reason he is aking me.. is he is doing a 1jz-gte swap into his lexus and told me his motor can take 15 psi without being rebuilt i guess he was just comparing motors
    My Lex is runnin 20 on the stock 2JZ-GE bottom end wit cams. But I dont know about the A6, I would say 8-12
    She's my 1st love!
    Originally posted by CustomLowz via greencb7inkc
    Hey, Grandma! You want a lumpkin?
    Oh,here comes one now! What now, BITCH!!!
      you can run 50psi.
      its not about how much you can run, its about how long you can make it last.
        He said running as an everyday driver. 50 wont last as a daily driver!
        She's my 1st love!
          x actly
          reading owns yak yak
            you cant compare an f22aX to a 1jz-GTE. the latter was designed for forced induction, hence it will always be more "reliable" than the f22a (stock for stock)
              that 1jz can get atleast 600 out of that stoc bottom end. with is its more like 250 11-12 psi efficiently tuned pending on the condition on how well its been kept up with the maintenance tops without breaking something
                Depends on turbo size on the 1jz and the setup of the motor. Ive seen people boost 10psi daily. There are some people running 12 I think on here also.
                  depending on the mileage of the motor and how well it is tuned I would not exceed 8 psi for a daily driver. 10 psi is pushing it and 12 psi will just cause failure.
                  "you can catch me swoopin 4G coupin switchin lanes" haha haha.
                  1993 SE coupe drag car ahoy!
                  1992 EX coupe 5 spd **sold **
                  Did work for: jhoff_cb7
                    seems to be around 7 psi for f22
                      well how many psi can i run with an f22b2 single cam???
                      Upgrade your mind before you upgrade your car
                      "So. Cal OUTLAWZ "
                        Im sure the same amount as a f22a1 that goes for f22b1 too! With a good tune Im sure you can roll 10 psi daily.
                        99 GS300 (Aristo) 2JZ Power
                        Bought from:gdout, bb6-sh
                          Turbo size + turbo parts? That might help narrow down otherwise its everyone's guess.
                            I was getting around easily on a T3/4 at 10psi. The 18psi spikes at the track on the other hand.....(see sig )
                            1993 Prelude S
                            F22A1
                            custom'ish turbo setup
                            180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
                            18psi boost spike = BOOM!!!!!
                            currently being rebuilt
                              What wastegate were you using? Boost controller?
