Need to grind the block...
    Well, i had my turbo setup for 2-3 week... on my f22a6.
    My setup was a 1st gen dsm manifold with a t3 adapter plate running a .60/.63 turbo.
    I had to grind the block so much (i made 2 hole, i could see the flywheel but i patched it with jbweld, i had no more engine code and no more frount mount thread)... but now i'm going to swap a f22b dohc but i dont want to grind as much as i did on my other engine. I know i'll need to grind put i dont feel like grinding everything.
    what i'm asking is there any aftermarket dsm manifold that will put the turbo a little bit farther or angled differently? what about the ssautoshit one? will it put the turbo farther than a oem dsm mani? And since its already t3 flange... it would put the turbo a little more higher?
    when i look in these pic, i feel there is a difference.
    oem dsm 1st gen
    aftermarket dsm
    Clock the turbo.
    Off topic: When does your turbo begin to spool?
      Originally posted by 90EX
      Clock the turbo.
      when i clock it its worst... it's already clock for the best fitment but still... too big
      turbo begins to spool at 2300rpm and get full boost at 3000~3100 up to 6500
        ssauto is good the 2nd pic is backfire32(Tim) he can tell you about that mani and he is still using it, go with it! But you will have to make a new ac line.
        99 GS300 (Aristo) 2JZ Power
        Bought from:gdout, bb6-sh
          A/C is already out since the second i owned the car
          cool, i will msg him... if he could get some measurement...
            with my 60 trim t3 i had to grind out the first bolt bracket back about 1/2 inch and the lower one i had to grind the top of the lower hole a little bit down and then it cleared eveything.more then enough clearnes to not grind into the block for sure with this manifold. and a much larger turbo will fit if u grind just the webbing and two front mount inner mount holes out i have found out. for my next snail soon to be replacing the 60 Only issue with fitment i encountered with this manifold is the one ac line that goes from the compressor to the upper hard line like trevor said but not a issue if u have no ac. and this ssautoshit has been holding up for well over a year now with heat wrap.
              o ya but the wastegate flange will either need a adapter to relocate it or u can simply cut it off and weld it at a slighter angle b/c it the way it comes puts it slightly against the alternator. this can be altered eaisly to make it work even if u can't do it urself it can be done cheaply.
                the first pic is my motor: with the stock dsm manifold and an adaptor plate, i can see with you need to modify the block more...however, with backfire's pic, his manifold is a aftermarket dsm already flanged for a t3, which offsets the turbo.
                Formerly 91AccordExR33
                11.68 @ 127mph
                417whp/375wtq
                Sold: 8/2016
                  amazing, i was scare to grind the block that far again so i think i'll opt for the ssautoshit. anyway, for the price they are on ebay, i think it worth the try. if i don't like it, i will sell it more than i pay on a local forum (damn ricer newbs!)...
                    have you thought of a thick exhaust manifold gasket? Not sure if it'd be enough tho, could possibly save you almost a 1/2" tho.
                      i was already running 2 exhaust manifold gasket
                      both were for the f22a but there were attached differently so i didn't have to modify them.
                      one was a oem honda and the other was a cheap napa...
                        those are thin, i'm talking about a THICK ass one. Probably wouldn't save enough room tho.
                          i have never seen a thick exhaust manifold gasket... i bet you have to change oem stud to extra long stud
                            Grinding my block is an understatement. My turbo is a 60-1 compressor on a TD06h turbine, in a dsm turbine housing, and a T04E compressor housing. I had to grind damn near the entire front engine mount upper bolt holes off. The one closer the the drivers side is gone, the one on the passanger side had to be removed about 1/2" to clear the compressors 3" inlet, and the bottom one had to be choped down. After all this i still had to remove even more metal off the block cause the compressor housing was contacting it...
                            12.5 at 114.6mph 15psi
                            11.7 and 11.5 20.5psi
                            F22a1
                            60-1 td06h turbo
                            Darton mid sleeves
                            85.5 wiseco 8.8:1 forged pistons
                            Crower pro billet rods
                            Custom ported head.
                            KMS valves
                            F23 headgasket
                            ARP H23 headstuds
                            H23 upper intake manifold
                            F22a6 lower intake manifold
                            Intake manifold is gutted
                            AEM EMS 1040u
                            FIC 850cc injectors
                            Walbro 255 pump
                            H23 manual trans
                            Prelude shifter assembly
                            Forbidden short throw
                            Nitrous Express Kit installed, never used on this motor
