Who has an EGT Gauge?
    Ive been thinking about getting an EGT gauge for my car, i hear that its good to know that temp so i can keep from trashing my internals. anyways i was just wondering if anyone has them what brand they like and how do you read it the autometer im looking at has numbers 0 thro 16 i figure 16 being hottest but what would you want the gauge to read?
    I may be wrong, but those numbers might be X10 (ie 14=140 degrees). I'm not exactly sure what woud be the ideal EGT. It may depend on what mods you have (mild to heavy), then again you may want your EGT to remain at a certain temperature range regardless of if your blown or just running I/H/E. I'll throw out a number and say ideal EGT might be 125-135 degrees.
    Good Luck!
    Bean Town Crew Member #3
    Lovin' the 6MT w/ Nav TL!
    "They Aint the REAL McCOY!"
      125? you have got to be kidding.
        hey he tried
        ideal is about 750-850 degrees Celsius...thats for WOT tho Partial throttle and idle area is usually in the 600- low 700's
        That 0-1600 gauge is in farenheit most likely.
        If anybody asks how to convert celsius to farenheit i'm gettin out the baby powder.
          cool so from 1382 to 1562 F which on that gauge we are guessing would be anywhere between 13 and 16 then right???
          And while i have mrx attention and we are talking about temp in the engine what is the perfect intake temp? and at what temp does detonation happen?
          Is there a gauge out there that reads intake temps?
            ur chipped p06.. can read Intake air temp... if u have the 4 pin header installed... antoine will know if he installed it on urs.. just like datalogging with the zeitronix.. (if u have it).. its the same way......
            Praise The Lowered...
              Thats cool but i dont have zeitronix i went with dynojet and if ya know mrx if mine can do that let me know . Still the ??? is what is a good intake temp?
                maybe below 100 for intake temps, something sane. Mine was low 90's in boost. And yea u should have the 4 pin header. Look for the hulog on moates.net and then use ecucontrol.com's program to datalog
                http://www.moates.net/product_info.p...products_id=78
                  Like i said, "i may be wrong" this was my disclaimer.
                  can't always be right. And when i'm wrong....i'm waaaaaay wrong...ask my wife
                    i have an egt, and i am around 650-700 c when i am in boost, but this is because i am running rich...they are def something handy to have, i have a blitz unit that i am very impressed with...
                    for intake air temps, i was getting like mid 80's when i was beating on it the other day
                    My baby laying down some power...
                    http://www.youtube.com/watch?v=kd_Q8HSIyqA
                      great! both ? answered i love it! you say you like the blitz is it just for reading egt? or does it do more? how much if you dont mind me asking and where did you get it? I really think im gonna go with the autometer one so all my gauges match. (so girl of me things HAVE to match)
                      Ill see if this ? can be answered in here too. i dont have a fuel pressure regulator, its on the list. but i am looking at the difference between the little shitty one that goes on the actual fuel rail, i guess its a manual one vs. the eletric one that you tap into your fuel pump? is that right? i dont remember i saw it on a teggy and thought it was cool. I like the idea the actual guage is inside the car with you so you can actually watch it. what do you guys think the manual one or the eletric one.
                        egt's raise when rich and lower when too lean. If ur a/f's are decent then you've got too much timing. Advanced timing means cooler egt's and retarded means high egts.
                          you got it backwards there toine ...the leaner a car runs, the hotter it runs (hence when you are running too lean, you melt parts) = hotter egt temps... the richer it runs, the cooler it runs.
                          midnightrayne, i got it from ebay with the sender and shit. think i paid around 200 for it~ it isnt digital, so egt is all it shows
                            http://www.foxvalleykart.com/egt.html - 3rd and 4th paragraphs from the last
                            http://www.bankspower.com/Tech_whyegt.cfm - "The richer the air/fuel ratio in a diesel, the higher the EGT will be."
                            http://hondatuningmagazine.com/tech/0510ht_fueleconomy/ - "Decreasing ignition timing results in lower combustion gas temperature but also raises exhaust gas temperature. On the other hand, increasing ignition timing lowers exhaust gas temperature, but eventually gets into the realm of pinging. "
                            See, I'm not crazy I thought it was absolutely retarded too the first time i ran across the info. But sure enough after tuning 1 or 2 cars with EGT gauges the theories held true. Think about it like this, if ur running very rich then the cylinder head temperature (CHT) will be low because the fuel was never fully burned, but that unburned fuel is still being burned and raising in temperature as it enters the exhaust stream.
                              wow i thought you were wrong as well. from my days of running nitro cars, it would be that the leaner you went-the hotter the engine got making more power, thats why its dangerous to run too lean. hmm learn something new each day.
