Why do the maps have to be redone? Doesn't the engine operate basically the same (especially at engine speeds out of the turbo's operating range)?
Questions about turbos in vacuum
Originally posted by 92exwhat do you mean maps redone? most people use the stock vac map, then add in boost and tune that section.
Elaborate a little
What's the highest level of boost you can run on the stock fuel system?
Originally posted by AcclipseH23Depends on the program. Haltech yes. AEM you can input your injector size and duty, and the map is rescaled automatically.
i ahve used AEM, Hondata Romeditor, Crome, Uberdata, Hondata Smanager....and NONE of them rescale well enough that I would jsut do a rescale and call it a day. Every single one of them I have had to do a bit of tweaking and messing with it to make it run like stock. But if running a little over rich all the time is your thing then thats you.
Originally posted by gloryaccordyAhh that's what I was wondering...cause I figured in vacuum the car is literally not making any boost, and other than the change in exhaust flow nothing's really different...
What's the highest level of boost you can run on the stock fuel system?Shift_BOOST
BOOM!
Originally posted by 92HondaEXthe injector scaling does most of the work, but it's up to you to fine tune it...Your sig is killing me...
I'm seriously torn between going all-motor and turbo...I had no idea tuning was so...easy. Datalogging pwnz and could work well either way...oh man...
