Bottom line is the sleeves are thin. If you not going to run in a safe low boost zone, then no you don't need sleeve. If you want to run higher psi then you need sleeves. Big price diffrence sleeves will hurt your wallet more then just lower compression pistion. Just go w/ what your instinct and wallet tell you.
Oh and post lost a pics and dyno sheets.
how much boost?
Originally posted by porc933I thought everyone was afraid of the sleeves b/c they are aluminum
Leave a comment:
Originally posted by porc933I thought everyone was afraid of the sleeves b/c they are aluminum and not steel they can't take that much boost. And if you mess it up you have to put sleeves in b/c you can't bore them. That's what Honda Tuning said, you can bore but it's not anything worth bragging about and there are not a whole lot of shops w/ the equipment to do it. IMO, if you're looking to make real power just sleeve the block, even if you run lower compression pistons that still doesn't mean the sleeves will be able to take the heat.
Leave a comment:
Leave a comment:
I say 10 reliably. the H22 sleeves are probably just as strong if not stronger than the F22 sleeves. its the rings you have to worry about
Leave a comment:
Originally posted by westsideaccordYep, probably get away with a safe 5psi tuned, maybe more but you may do some serious damage if your not carefull! They are making new pistons for h22 that lower compression for boost, without resleeving! If I still go that route, Ill def be using them! (I dont remeber who)
they will tell u every thing u need to know the article was in honda tunning march and a little in april
IT,S THE SHIT.
I have not went to it so i don,t know im staying single. if they dont tell u all the info i got both mags ill be happy to try to help.
Leave a comment:
Leave a comment:
the compressoin and sleeves and rings is what you need to be worried about. No more then 6 psi. But that depends on the turbo
Leave a comment:
The compression ratio isn't what scares me, it's the sleeves' tendancy to crack that scares me.
Leave a comment:
how much boost?
How much boost can you safley push to a stock jdm h22 bottom end? anyone know? Ive got a turbo but I dont know if i want to install it with out building my bottom, depending on how much boost I can push to it. id probably have to change out my stage 2 cams back to stock because of the high compression ratio right? any input would be appriecated.Tags: None
Leave a comment:
