ok, im going to be starting to get turbo parts together and i needed some help on different turbo's and manifolds and other parts needed, i was thinking of going to pick-A-part maybe and wondering what kinds of mitsubishi eclipse' and talons turbo and manifold would be the best?, what years of cars would help too, and tsi..whatever model woukd work in my 92 accord with sohc f20a engine, thanks
turbo project parts help
to be cheap i'll suggest (if you have f22aX engine) yo pick a dsm manifold... then make yourself a t3 adapter... then take a saab, volvo turbo or in the best case... a thunderbird t3, .60/.48... then pick up a dsm bov... get a CCA (custom coach intercooler... from the groupbuy on homemadeturbo.com sales section)
get some 450cc injctors (dsm, or rx7) get a chipped p06... then make your custom piping using 2.5" mandrel bend...
make a 3" dowpipe
get a boost gauge and oil pressure gauge on ebay
get your vacuum line and coupler from homedepot...
get an oiline kit from stealthmodeperformance.com
get a new clutch from lsdmotorsports.com
get all your gasket/bolt/misc stuff from you local honda dealer...
sorry ... i'm fucking drunk
Originally posted by labatt50to be cheap i'll suggest (if you have f22aX engine) yo pick a dsm manifold... then make yourself a t3 adapter... then take a saab, volvo turbo or in the best case... a thunderbird t3, .60/.48... then pick up a dsm bov... get a CCA (custom coach intercooler... from the groupbuy on homemadeturbo.com sales section)
make a 3" dowpipe
Originally posted by 92HondaEXhuh? If you want cheap, go all dsm turbo but you'll suffer from creeping and boost cut-off. And you probbly don't want a .60/.48 as that will be either too small of a turbine or compressor housing. And rx7 never had 450cc(only dsm)....word of advice, the rx7 460cc injectors doesn't work at all(I know, I tried) and go with dsm 450cc black top injectors and your set. If money wasn't a problem, I'd go with a t3 60 trim turbo as many has said it work well on the cb7's, or do what I did and bought a cheap turbo and got a smaller turbine housing to match where I want to be.
1. The Thunderbird turbos are .60 turbine and .48 compressor. Thats nice for an entry level kit. The DSM turbos are much smaller than this!
2.There are 2 types of RX7 injectors. The high impedence red tops and the low impedence black tops. Our CB7s need the black ones.
3. As for the coupler advice, reinforced silicon only. That other stuff tears easily.
4. DSM kits can have boost creep avoided with a large diameter downpipe as well as a large diameter O2 housing.
5. Our turbo bible is set to release some time today. I am still working on this with MRX. Stay tuned.Last edited by KillerCam282; 01-15-2006, 09:25 AM.
Originally posted by AcclipseH23Easy, labatt50 knows his stuff here. Even when drunk, suprisingly.
That was pulled off of here. And the problem with boost creeps are with the wastegate, so look for a t3 then.Last edited by Clueless; 01-15-2006, 11:36 AM.
Originally posted by AcclipseH23The infamous tan tops...I forgot thats the color. Good find. The actual WG problem is the flapper, not the actuator. It needs a bigger exhaust to vent into.
Originally posted by 92_accord_f20athanks for the help so far..
ok, so what year of thunderbird would i want to pull the turbo out of, and would i grab the manifold from what year of eclipse, or would a different one be better
Originally posted by 92_accord_f20aso what year car and model would the t3 mani come off, and would the thunderbird turbo be good, what year thunderbird would i be looking for?
but yea dude, if you want cheap, then just go with a full dsm set up. Get a big 16g, 2nd gen manifold, 1st gen bov, cca intercooler(from hmt), oil lines from stealthmodeperformance.com, charge pipes from sparkle, couplers from home depot, and all your tuning accesories from xenocron.com(chipped p06, rom burner.etc....).
that cheap^^ imo.
-Jose
