Traction problems...
    Just wondering, any of you guys putting down some power have problems starting off in the rain? Seems like a will either feather it till I almost stall, or sit there and spin my tires all the way through first in the rain. And yes, I have good tires.
    Shift_BOOST
    BOOM!
    I'm not putting down serious power and I have tractions problems all the way thur first and into second if I punch it.
    Oil leak?What oil leak? That's just sweat from all that horsepower!
    Applied knowledge is power!
    NITROUS FOR YOUR BODY
    BIRTHDAYS ARE JUST AROUND THE CORNER
    registration is free
      I find first gear to be useless. If you feather it in second you should be fine.
        I almost always start out in first gear in every kind of weather. I don't spin my tires unless I mean to. Normally I rev the engine to 1500rpm and feather the clutch out untill my foot is off the clutch. As long as I don't stomp my foot down on the gas it won't spin the tires.
          92ex is turboed, I believe.
            My turbo is a bit bigger, but as long as I'm easy on the throttle, I don't have to many problems. Ice on the other hand is a totaly different animal, after turboing my car driving in Minnesota winters was impossible. Just take it easy and shift to 2nd as soon as you can. L8r
            Turbo H23a3 build has begun
            01-01-2019
              What size is your turbo? That would be helpful info to most. Also where does it begin to spool?
                sounds like you need an alignment
                and wrong wheel drive will almost always result in traction problems
                  I cannot seem to relate these two things, can you show the relation?
                    Camber helps around a corner, but limits the contact patch that will let you accelerate in a straight line.
                    What do you mean by "good tires"?
                      t3/to4e .60/.63 with stage 3, 57 trim wheel, non ball bearing. Spools on the h23 at 2500, full boost (7psi) at 3300. L8r
                      01-01-2019
                        If he is talking about losing traction when trying to move from a stop in rain, but not on dry i strongly doubt camber would have anything to do with it. This is the impression I am getting from it.
                          You just need better tires and need to learn how to drive better. Noone really gets traction in the rain including me so not to worry,especially in a fwd car let along a rwd even worse.
                            Now how come at the meet you couldnt tell me that??? Thats the exact turbo I want/getting....
                            Good tires= New bridgestone potenza g009. Nice grip to them
                            Its only in 1st gear, when it raining i spin my tires. I either feather it out and my car stutters like its about to stall, or I feather it out with a little more gas and my tires spin. And i have the 14b turbo, so im making around 130whp around 2000rpms if that helps
                            Shift_BOOST
                            BOOM!
                              And about the same TQ. So thats why. Nothing much to do abot it, unless you want to cut the boost down. Pick up one of those adjustable actuators. However, they cost a pretty penny.
