thinking of bumping up compression
    I've been looking at pistons and I found some arias 9.4 to 1 ratio pistons and I was thinking about those because they come with wrist pins and rings and I also want to bump the compression up a little bit. My only concern is, is this too high for boost on the fseries?
    ricers make baby jesus cry
    no not at all but why?
      Cause more comp means more power without a high level of boost. Also makes the engine VERY responsive. I was actually gonna do 9.5 - 10:1 myself. To be thinking of this u kinda have to have a general idea of the power u wanna make vs the available and highest octane in ur area.
      p.s....with the luck that u have with f-series...i'd keep it stock or lower
        also, what u may wanna do is get a general idea of how much boost u need to run to have the turbo in an efficient psi throughout the rpm range u want. Then compare that number to other hondas with similar compression and notice how much boost they're running and if they're on race type gas or pump gas.
          yea i got my head milled 40 thousands over which brought my CR to around 9.3 -9.4:1.... at 7psi it pulls harder than my stock engine at 9psi.... its also a lott more responsive like mrx said.... i have a lot more low end power from all that fukkin turbo lag and i start to see boost by around 2500 now instead 2800 and full boost by 3300 instead of 3700.... my 14" steelies my 1st and 2nd gear are just good for loosing traction if i have it over half throttle...
          oh yea and thats on 93 octane...
            Its the reason why I milled my head on my F22b. And I am also seeking 9.5-10 CR on my buildup. Lower boost can still pwn on higher CR setups.
              I will be running on pump gas, we do have 93octane in my area but most stations are switching to 92 and like everyone else stated I want to make more power on less boost, and actually have some sort of power before boost hits and faster spool up. Thanks for everyones input and if you have more it will be much appreciated
