Originally posted by Granite CB7
compression test results
Tested mine tonite. 160k N/A miles:
187-186-186-188
that was with about 10 cranks... they were all about 175s with 6 cranks then it just goes up by smaller and smaller amounts. Also my guage wasn't too accurate so my results are +/- 2 psi. There is only a mark every 4 psi so I kind of guessed on where the needle was... there is also a slow leak in the connections because I only make the adapter finger tight into the head. So if I waited longer to make a reading from the gauge that reading would be slightly lower than it was a matter of seconds ago because of the leaking pressure.
hold on to your butts
180, 190, 180, 190...second try 180, 193, 180, 193, third test 180, 194, 180, 194 lol...i have a valve stem seal leak so everytime i restart the car a tiny bit of oil goes into #2 and #4 and raises the compression. Yea...i make more power everytime i start my car talk shit now bishes !Knowledge is power...in EVERY sense of the word
Mines 195-190-190-195. I tested the motor before I bought it and got the exact same results 5 years and 70k miles ago. Also, a leak down test is much more accurate then a compression tester, but alot more expnsive and complex to use. I had about 2-5% leak down across the board. L8r allTurbo H23a3 build has begun01-01-2019
210 , 200, 200, 210 here1992 Honda Prelude S - Swapped F22A6 - Turbo 16g Powered!
Mods: 3" Exhaust,450CC Injectors, DSM Manifold, DSM Ported 16g, Stealthmode Oil Line Kit, RFL BOV, JDM Black Housing Headlights, Clear Corners, Tinted Tails, Forbidden Short Shifter, Front Mount Intercooler, Chipped and Tuned P06 ECU - Tuned With Uberdata, Lowered 1.7,6 Puck Clutch"
PARTING OUT F22A1
