compression test results
    just trying to see the range of compression test results from the chosen, boosted few...i got 210K on the motor but haven't done the test yet so i am curious who's high and who's low....thanks all.
    My Old Ride Thread
    You want to be above 140 (160+ H23, 180+ H22), and you want it to be even; as in no more then 15 PSI difference between any of them
    Originally posted by DoctorCipher
    ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
      i gotta do my test this coming week to see....i haven't seen too many posts with results so i figured i'd ask. i got the kit and got another motor lined up, in case....
      My Old Ride Thread
        I got 185psi all across four on 91 accord 118k miles "stock"
          i got 150ish across the board on my f22 round 200k
            this gives me hope that my current motor will last til summer when i'm done building the other motor....i don't plan to jump on it all the time so i'm hoping low boost (4-6 psi) will last that long....
            My Old Ride Thread
              175 across the board here with 160k on it
                A motor will run with 100 PSI compression, but it won't make much power, and probably burn a lot of oil (or have a lot of gas deposits in the oil)
                  o yah my head was warped then to so it might be a little diff. now
                    180-180-180-180 here
                    h23a3 cb7 turbo sold
                    FS: 1 Piece JDM Headlghts blackhoused
                    My Members Ride !
                    New ride
                    '07 GTI Mk5 6spd
                      same, 184k too
                        190-195 across the board...
                        My official vouch thread!
                        Updated!!! --> My official turbo progress thread
                          Okay, I have a quick question: Is it something I'm missing but why are all you guys' compression #'s so high? Is it b/c you did your checks while being turbo'd? You wouldn't see any boost while checking compression or would you (thus upping the comp. #'s)?
                          Originally posted by HondaFan81
                          Helms manual info for F22ax motors:
                          178 psi Nominal
                          135 psi Minimal
                          28 psi Maximum variation
                          Examples:
                          hurricanedsm-185psi on all 4 @ 118K (stock)
                          prodigymb-180psi
                          midnite racer x-180psi @ 184K
                          92HondaEX-190-195psi
                          Why are these #'s so high being that 178psi is standard? These 4^ are all using the F22aX block w/ stock compression (I believe). I'm sorry for the noobish question
                          Dan
                            it will trust me just make sure you keep up with the maintenance and you should be straight and boost conservatively heh like thatll happen lol.
                              Examples:
                              prodigymb-180psi
                              Dan
                              Some people may be forgetting to disable the fuel injectors when they run the test, which will definitely inflate the numbers.
