i have a 93 accord and i was wondering if you did the turbo set up can you keep the front motor mount? If you can't keep it what can you do to make it not have the mount but the car still acts as if it does..
F22A1 turbo motor mount question
Originally posted by ChroNicBoosTyea its deff complicated to keep it... you would have to either build your manifold to work around the mount, or such as my own setup with a huge t3/t04e, i relocated and chopped the stock mount and its sittin where my A/C bracket was...
thanks, chris
naaa you cant even see it in any pixx i have, plus its completely hidden from view... its right below the power steering pump thats why its camo.... what i did was cut out the mount from the front crossmember and unbolted the upper mount on the block... i cut abouttttt 4 or 5 inches out of the mount and just welded it back together... i welded the lower mount more towards the driver side and mounted the upper mount where my A/C bracket was... it looks stock how its set up so jus picture the mount on the A/C steeering pump side of the block... i also just ordered an engine torque damper which is basically a piston that helps absorb and reduce a majority of the rocking from the motor and transfer it to the ground better with less wheel hop and such.... i also purshased a Prothane urethane rear mount insert to help out with the rigity as well...
