Anyone knows how to get in touch with him?? He barely on. . .
Wheres Accord R33??
everything you asked me in the 4 consecutive PMs you sent can be found by searching...Last edited by Accord R33; 11-03-2005, 11:15 PM.
The block feature works well, doesn't it?
I PM you about that chip i talked to you about but you never got back, due to the fact i cant get the wideband anytime soon. I also wanted to know if you still are selling those turbo kits. I'm intrested but i have some parts already so i dont need all of them i have the Ecu alread, the manifold, the charge pipes. Pm me a price if you sell it taking off all the things i have already. I might be able to get the injectors and the BOV
Originally posted by 92_ExaccorDI PM you about that chip i talked to you about but you never got back, due to the fact i cant get the wideband anytime soon. I also wanted to know if you still are selling those turbo kits. I'm intrested but i have some parts already so i dont need all of them i have the Ecu alread, the manifold, the charge pipes. Pm me a price if you sell it taking off all the things i have already. I might be able to get the injectors and the BOV
Originally posted by Accord R33there are a VERY limited number of people who have my screen name. i try to keep it that way
Praise The Lowered...
Originally posted by 92_ExaccorDDo you know if this kit would bolt up on the 4th gen accords (92 Ex)
http://cgi.ebay.com/ebaymotors/Ecli...010719269QQrdZ1
Originally posted by 92_ExaccorDhow do you control the boost of the turbo manually?? and how dou you guyz keep it @ only 8psi??
Do you think its possible to run 10psi daily?? also what kind of power will that produce??
Originally posted by 92_ExaccorDI have some other questions if you dont mind. . .
Anoother thing im still not clear about is how to chip the ecu, is that the same thing as tuning??Is it true that you can use a gameboy sp to tune ur turbo or sump?? What would happen if you used a stock ecu?? Is the power ur puttin out with or w/out p/s a/c ?? Did you up grade any pumps like the water pump and the internal fuel pump??Originally posted by 92_ExaccorDI was just wondering if that was the same setup you have/had. And if yes what was the hp/tq it was pushing at what psi. I also wanted to know about how much it cost for all the things you needed. And who chipped you ecu?? Or did you do it yourself. Also would you know what is the max output you would get from this setup and how much psi you could take it to with a built bottom half??
there was only ONE PM about pricing on a chip..and i replied to it.
all those questions have definetly been covered pretty clearly especially chip/tuning and prospective power #s.h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
