turbo size on f22a6
    turbo size on f22a6
    would a .70/.84 turbo be too big for my f22a6 100% stock or what would be the ideal size for at least 230hp? i know it could be achieve with a .42/.48 but it seem too small... and no room for improvement.
    And also should i use 2" charge pipe or 2.5"?
    When i had my turbo setup in my civic is was easier to find answer... i had a rhb5 with 2" charge pipe and it ran fine. But it was with a 1.6l engine.
    I might have a low post count but i read a lot, and found some interesting stuff, but haven't found answer about the turbo size...
    all i can say is that the bigger the better just be careful how much u boost .............
    92 accord dx....traded
    97 accord ex....traded
    93 civic si ....stolen
    96 tercel ....sold
    97 ek hatch b17 ..traded
    97 civic 4door b16 sold
    04 tsx traded ...for a honda coupe (top secret)
      Originally posted by zoomspeed05
      all i can say is that the bigger the better just be careful wat u boost.............
      yeah... but will the engine be able to spool this turbo?
      i prefer to achieve my hp goal with 7-8 psi than running 12psi...
        that looks kinda big. You can hit 230whp easily with a smaller turbo. A lot smaller.
        Shift_BOOST
        BOOM!
          LMAO!!! That .70/84. I thought I was power hungry! Too big. DSM 16g perfect for that. I got 231whp (unofficial ghetto gtech pro dyno) on 14b.. much smaller than that rhb5...(isnt that bigger than a 60-1?). Start small, build your block then go big.
            get a 16g. its not to big, and its not to small
              16g sounds fine. Truthfully though it would be better to work on the head and run lower boost...turbo cams (high lift/medium duration) would probably do wonders for our car. Who's gonna be the first to break 250whp???
              Originally posted by lordoja
                This would be on a DSM setup I am assuming...well then...ME!
                  i think antoine gone and done it already. or at least close enough
                    But, Toine left DSM...or is this on a DSM setup?
                      antione never had a dsm setup. hes using a t3/t4 ball bearing. labatt knows his shit, so he's far from a newb. read many of his posts on HMT. anyways, use the shit that you have, with some big injectors. like the other guy said, i'd get a cam for a turbo application, to open up the head a little bit, maybe a port and polish. f series heads flow like ass. if you don't use that turbo, look for a big t3.
                        You obviously missed my buildup thread...And i got a 700whp Z on 93 octane...I think I know a lil something about turbocharging...(just a lil) .
                        Project Homebrew
                        The reason why the injectors were not picked for that turbo is because I feel that with proper tuning I can get away with 1000cc injectors and keep them for a larger turbo in the future. And lets not mention, I have my turbo cams already...
                          acclipseh23 speaks the truth
                            Thanks for the input guys.
                            Well, its a hard choice for me cause the turbo i'll be using
                            depend on which manifold i'm going to get...
                            i'm undecided between the redrilled dsm with the t25 flange
                            or a h23 manifold with a t3/t4 flange...
                            is it me or t3 turbo are more easy to have in good condition for cheap than big 16g?
                            the turbo i'd like to use would be a .60/.63 but why i asked if a .70/.84 would work is because i know someone that would sell it to me cheap. But i know f series dont rev high... i would definately use it on a h22 setup
                            rhb5 that i use on my d16 was as big or even smaller than a 14b... its the one from a ford anal probe gt or (mx6 gt, 626 gt), rhb5 vj-11 to be precise
                            thank you! i never though someone would say that to me, that's cool!
                            It's so hard to switch from the civic world to the accord... its completly an another world! i must "re"learn everything
                            and "voila" my new car... i just can't wait until monday!
                            accord ex-r 1993
                              ...rhb5 that i use on my d16 was as big or even smaller than a 14b... its the one from a ford anal probe gt or (mx6 gt, 626 gt), rhb5 vj-11 to be precise...
                              You know...I think i confused that with the RS-series turbos...once i saw the trim I automatically thought you were thinking of the large ball bearing turbos...my fault.
