Is my current turbo ok?
    all of you turbo guru's out there. my current turbo is a mitsubushi TE04H. Is it good for 10 psi? Not just psi, is it good for cfm's @ 10 psi.
    Turbo f22a/f22b vtec
    its a baby snail...you COULD use it but it''s not compatible with any tdo5h parts, which you'll eventually want.
    I hate thieves!
      TD05H? is that a larger version of mine? i have that funky offset turbo flange too. that chrysler one. Will this turbo your talking about still fit?
        Wow that thing is pretty small. It will probably choke that motor out. If they have the same flange (probably do), Step up to a 14b or T25 for now. You may quickly grow tired of that to so a 16 or a big 16 would be cool.
          if i could do it all over again. i would certainly go with the biggest turbo i could afford (within reason of course).
            well what other turbo's share that same flange pattern? again its the funky chrysler flange.
              Due to its name I would think so. I would look into it if I were you.
                what other turbo's have this flange? come on turbo guys
                  You are the one with the flange and the turbo!!!
                  Most of us (i can seriously vouch for that) never seen that up close so we would not be able to tell you. Compare your flange to the 14b and you would be able to tell from there.
                    _______________________
                    | ____________ \
                    | O | | O \
                    | O |____________| O \
                    |__________________________\
                        tried to make a pic of the flange
                        here this is better
                        http://www.imagestation.com/picture/...2/f5c75d64.jpg
                          No. It will not fit directly. However, you got some meat there. Drill it through for the 14b to fit.
                            i have another turbo that needs to be rebuilt. on the exhaust side it says garrett m3. what's that? the other side is polished and has a plate on the back that says "Cust p/n UPGRADE" and it has serial numbers
                              any 1?
