...ok so i know this is possible ...but i need to see some pics for refference and i need to see peoele parts lists that they used ...
im planning on using ....
dsm manifold
14b turbo
wastegate
bypass valve wich will be recirculated i dont belive in venting
and a starion front mount innercoler
and injecctors im not sure if i wanna use the 390's or the 450's ill see what kinda numbers im looking at boost wise ...
then i guess i will need a boost crontoller
i think i can also figure out a way to use the bulk of the dsm exhaust the o2 housing and make the test and j pipe .....i will have to do some fitting ...but yea if there were some pics that would be amazing ..
and maybe some lists of what you you used for yer turbo kit
dsm manifold
14b turbo
wastegate
