well this week i blew my head gasket again. 2nd time on my new motor with only 3000 miles on it. I think i know why it went this time and the previous time.
Ok, stock bore of the F22a is 85mm. My motor is 85.5mm. My pistons also stick out of the block .030"
Even though my pistons fit through the OEM f22a headgasket, i think it rubbed it. When i blew the 1st one i noticed it looked like cyl. #1 piston rubbed the hg.
when i replaced it i noticed even on the new gasket it had a little imperfection in the same spot...
I talked to a few old drag race guys a while ago about this. They told me that if the piston does touch the hg, it will leak right there. And thats what happed the 1st time.
So heres my fix.
I'm going to install a head gasket off a 2000 accord 4cyl vtec F23 thesemotorsarfe 86mm bore. The only difference in the gaskets is the bigger bore, and it also has a few steamholes in it, which the F22a doesnt. It will be fine. The only think i'm going to modify on the gasket is 2 holes on the passanger side of it that are not cut out. Im going to cut them out like the F22a one.
I also ordered a set of ARP H23 head studs. This should be the last time i'm going to be changing this.
Before i built this beast of a motor i knew i had the possibility of having this issue. Well i have it and i think this is the fix for it. So, thats it.
Peace
So heres my fix.
Peace
