Ecu question !
    Ecu question !
    so my T25 shit it self b4 i even got to charge piping and i decide to get a brand new evo iii big 16g. my ecu was programmed by eric for the t25 setup. will this make a huge difference while i drive the car to get dyno tuned within couple of days?>
    h23a3 cb7 turbo sold
    FS: 1 Piece JDM Headlghts blackhoused
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
    It can due to the change in CFM. For optimal performance i say get a retuned ecu. By the way is this Eric as in AccordR33 or Eric from Ericks Racing?
    P.S. If its the latter, someone should kick you many times. j/k
      you can drive it just stay out of boost. How far is the dyno?
        Thats easier said than done with a big evo turbo. Does that thing start boosting just under 3k? Or maybe around 3k...Hmmm (I'm about to go out so I can't search this and make sure).
        Last edited by KillerCam282; 08-13-2005, 08:19 AM. Reason: You got to love my grammar.
          oh and if u want a very good safety feature...just disconnect a charge pipe, you don't even have to take out just make it so can't really build boost. If the ecu doesn't read boost then it won't dump in fuel to compensate for it.
            ^^^I learn something new every day. I never knew that.
              well yea the Manifold Air Pressure Sensor reads the pressure and the distributor sends the rpm signal. The ecu accepts and calculates the two and sends a signal to the injectors to open for X amount of time. So if the MAP sensor only sees 0 vac it'll only send the fuel programmed into the map for 0 vac even tho the turbo itself could be at like 20psi
                sounds lika a good idea . dyno is 2 hours away highway driving ! i dont wanna really disconnect the piping because it could make the car run really shitty on highway. can anyone send me their working evo3 big 16g map? that would be appreciated so i can give it to the guys at the shop.
                My Members Ride !
                New ride
                '07 GTI Mk5 6spd
                  why would it make the car run shitty? Just put an air filter over the pipe that leads to the engine as if it were n/a. It'll run exactly the same
                    yeah, or even switch back to stock ecu with charge pipes connected, then when you hit the dyno, put the charge pipes on and chipped ecu in.
                    Shift_BOOST
                    BOOM!
