Rear mount turbo
    Rear mount turbo
    Does anyone have any experience with a rear mount turbo kit?
    I have seen it for V8 and V6 applications in Camaro and so on.
    I like to build a set for my 91 F20 engine.
    Cheers,
    Pj
    No Honda There will be one eventually...
    1996 Volvo 960 2.5i 24v autotragic
    you mean they mount their turbo's back by the rear axle right??? i've seen some on camaro's but not on accords. the only reason they do this on camaros is because they have no engine room to fit a manifold and turbo.
    our accord's how ever can fit a turbo manifold and turbo in our engine bay, so we dont need to do that.
    if your f20 has the same port design as our f22a1 fuel injected, then u could do a DSM setup. for me info on a DSM setup, check out hondasociety.com or honda-tech.com
    91 4DR Accord LX White Auto
    Generic Mugen Lip
    Generic Intake
    EX 4-2-1 Header
    Dynomax Muffler
    Skunk2 Coilovers 560lb/in and Koni Yellows
    ST Rear Sway Bar
    17" Eagle Alloys/Kumho 711's
      I've seen camaro's with the turbo mounted under the hood.
      I also have the problem that my car is equipped with carb rather then fuel injection. So i'll need to modify the carb or try to fit it with an other carb that can be built for a blow thru set up.
      I already built a chev 267 V8 blow thru setup and it cranks out 350 horses @ 5000 rpm
      Pj.
        Check www.ststurbo.com there you can see a rear mount turbo kit
        Pj
