Originally posted by midnite racer x
F22 turbo 92' lude vs. h22 94' lude
Originally posted by DoctorCipher...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
WTf is that pipe stickin from under the car there my shit is a lil low on that on the driver side but not that low. I suggest you find someone or try to shorting and tuck the pipe up higher undert he chasis out of the way last thing you want is something flying or popping off on the highway or hittin a bump or runnin away from the cops.
Originally posted by InvaderTraxHe already listed it several posts up. Anyway, what pipe is that sticking out from under your car? Cause there might be a hole in that. I'd suggest tucking it up a little higher from the roadKnowledge is power...in EVERY sense of the word
Originally posted by Mkai0I have an aftermarket stage 1 ACT clutch, 450cc injectors, saab blackstone intercooler, 2.5 inch piping, 2.5 inch exhaust from front to back, safc2 for engine management, turbo xs blow off valve, joe P manual boost controller, custom turbo mani, rebuilt garrett T3 turbo off a chyrsler lebaron w/ internal wastegate, and I did get the car wideband tuned.
Originally posted by iamanonymousoooh antoine...pwned
I'd say check for leaks at the manifold, leaks in the pipes of the charge pipe and not just at the connections, distributor timing, and might wanna do a compression check too. But for the little that you have...yea i'd say thats about right, your probably making just over 200whp and his gear ratio's probably did you in....it may also be your driving. Launching is everything in a race and from a roll you may wanna try brake boosting.Knowledge is power...in EVERY sense of the word
In reply to the question about the intercooler pipe hanging out in the front, I am using a blackstone bar and plate intercooler from a Saab, so both intercooler pipes go to one side instead of going to two sides. This caused me to have to cram both pipes on one side giving me less room under the bumper. I could have mounted the intercooler higher, but that would have made the intercooler less efficient because of blocked air flow. The pipes are very thick steel, and I have scraped a few times, but it is not very bad at all once you know how fast to drive over certain obstacles. Midnite Racer x you may me right about the leak at the manifold because I did suspect something going on around there as well. Also didn't you smoke a S2000 on your setup? I just did't think small leaks would make a huge difference on horsepower. Oh yeah and the specs on the turbo are .42/.48, and can anyone tell me if I upgraded this same turbo to be a T3 super 60 would this make a big difference in my potential?
