Difference in times using LSD
    Just looking for anyone who noticed a big difference in their 1/4 mile times after installing a LSD. Reason I'm asking is because I've seen more than a handful of turbo Accords out there on forums and such, but always talk about tons of wheelspin. To me, that's a lot of wasted hp, and I would like to be a little more effective at putting power down after I finally get mine done.
    Look at the sig for current mods....just need to get it tuned.
    Thanks in advance for any advice/imput.
    F22a1, T3/T4 turbo, Greddy Type RS BOV on left-over AEM CAI piping, Turbo XS manual boost controller, PHAT intercooler, Crzy tuning, Walbro fuel pump, AEM FPR/fuel rail/pulleys/cam gear, Gude cam and throttle body, MSD ignition/cap/coil, NGK wires and Iridium plugs, Fidanza flywheel, ACT clutch, Nuespeed short shifter
    9 lbs on stock internals (for 10 min)
    16.2 1/4 mile with basics
    ??.? 1/4 mile with turbo
    139 hp with all bolt-ons
    ??? hp with turbo
    STAY TUNED
    I was told you could shave a 1/2-1sec off your 1/4 time. Correct me if I'm wrong.
    Midwest car club
    Current rides:
    91 accord lx (5spd)
    92 accord lx (5spd)
    93 accord lx (auto )
      Well say your 60' ft was 2.4,which is bad.I'm guessing lsd/good tires/skilz would help drop it to a 2.1-2.2 wich would be half a second on the 1/4,so yeah you are right
      People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
      Mk3 Supra Member #2
      Originally posted by DarkShadow707
      The world needs to be reset.
        I already have 2.2 60 ft times when I was NA, so maybe I have nothing to worry about. My other concern was the cost of a Quaife in order to get me to 13 seconds or better on stock internals. That's my true goal. 13's in a 4 door sedan kicks ass!
        ??? hp with turbo
        STAY TUNED
          damn fuckin right!!!how much boost are u pushin?
          Edit:o yeah 10psi i think 13"s is atainable
          Mk3 Supra Member #2
            Quaife's are very good, i wish i had one, plus they are rebuildable for free with there lifetime warranty so if it ever breaks (not likely) they will fix it for free.
            JDM H22a
            P2T4 tranny
            I/E, CM ultra-light flywheel and CM stage 1 clutch
            16x7 Rota C8's in bronze
            nitto neo gen, 205/50/16
            custom short throw shifter
            Tokico Illumina RAK Coilovers
            Power Stop Cross-Drilled Rotors, Honda Pads
            Honda Torneo Shift Boot and Knob
              correct me if i am wrong, but an lsd will only make better use of what traction you have available, not make the wheels slip less
                Open diff=more power to wheel with less resistance
                Limited slip diff=power distributed evenly.
                So yes and no at the same time. See with the open diff and lots of torque, hondas tend to peg leg on launches. With the lsd both wheels will spin but two wheels will always hook faster than one.
                  thats why i have one on my car
                    WRONG! you dont think youll have a problem with wheel spin when you push close to 190 whp? i mean with your stock na your pushing maybe 104whp, think again buddy boy. even with lsd you are gona spin your tires alot, just not as much.
                    its not like LSD is magically gona make it go away.
                      can we get some pix of the t3 on the dsm mani? Did you use an adapter? I need to look at the clearance between the turbo and the radiator fan shrouds
                        ^^^ Was wondering the same thing... t3 on dsm mani? and no injector upgrades?
                        Shift_BOOST
                        BOOM!
                          It's a Saab T3, I think, with the air coming into the turbo 2 inches from the powersteering pump. I'll see if I can get a picture of it posted when it's done, which will be soon I hope.
                          Also, I am using DSM 450's and SAFC.
                          The turbo is welded on, and I need to reinforce it.
                          Last edited by carbonaccord69; 07-17-2005, 06:39 PM. Reason: need to add something I missed
                          ??? hp with turbo
                          STAY TUNED
                            The OBX LSD is half the price of a Quaife. However, the OBX may be a piece of junk. Anyone had any experinces with it? Regardless I would invest in the Quaife
                            600HP" 1990 ACCORD LX COUPE COMING SOON
                            CLICK HERE TO VIEW MY 1990 CB7
