I put in a 14b w/ 450cc's on my car this past weekend, it is all up and running alright. I did the NGK plugs 1 step colder and closed the gap to .028" and bought a new cap and rotor but these things did not help the situation. The only thing wrong with it is that it will not idle good. It will idle "OK" at 850 or so for about 15sec then it will drop to about 550 and almost die then will shoot back up to 850 or so but it misses pretty bad the whole time it is at idle and up to 1500. When I am at about 2000rpm and above and even under boost it runs perfect no detonation or anything pure power not even a miss but when I slow down it just seems like it doesnt want to idle for shit. The ECU is from R33 so it must be great I mean no CEL's and great power!!!! (thanx Eric) but I cant seem to figure out what is causing it to run so horrible at idle. Any help would be great!!!!!!!
need help with my turbo quick!!!!!!
mess with the plugs.... -justin-
MY SH!T FOR SALE!
H23A1 (60,000 miles)
tranny (no grinds)
ECU
DC header w/ heat wrap
full exhaust with angled N1 Canister....
$1000 obo delivered
SOLD!
I tried checking for vacum leaks and nothing, I dont know where else to look at. I had weird luck today when I was running my A/C today it ran perfect while it was on, just every once in a while the idle would drop but not that bad!!! I guess it is a vacum leak but where else do I check any suggestions!!!!
like they said, check your idle valves, adjust your idle screw, ect ect. the new chip is on the way, hopefully it will solve the problem. ill continue to try my best to help you out
How can I adjust the fast idle valve I dont see anwhere to adjust it and as for the idling screw I did mess with it but?????? Also I regapped the plugs to .030" and that did not fix the miss. The miss fireing is my main concern because it only does it at idle but anything above 2500 RPM is absolutly beautiful no misfires or anything all you hear is the BOV and turbo!!!! sounds real good too
