Clicking boost solenoid & running lean
    Looking for some help here as I am officially lost.
    H22A
    S300 V2
    3bar map sensor
    All was running just fine. I did a fuse box extension to move the fuse box to the rear and car ran fine. Stalled once or twice at a stop sign which was new but from my knowledge this is not related to the work I did. This seemed like a dirty IACV issue. Noticed when it did this stalling thing it was running really lean, 17 A/F ratio for a second or two.
    Took it home and cleaned out the IACV. Right after doing this the boost solenoid clicks really loud and fast as soon as I turn the key to ACC. The last time this happened I had the map sensor unplugged. Checked all the wires around the IACV area, all were plugged in and into the proper spots.
    Tested the map sensor, it tests fine. Put the fuse box back in its original location with default ground, same issue.
    So now I have the car running lean with black smoke slowely rising from the exhaust, have left over fuel in the cylinders, and it will not start.
    .....and i'm not sure why.
    Any help is appreciated. I think as soon as I determine why the boost solenoid is on/off really fast i'll have the problem solved.
    17:1 AFR is lean.
    something is telling to dump fuel, thus excessive smoke and a no start. pull up s300 and look through parameters and see if anything looks off.
    COUPE K24
      Originally posted by '93CB7Ex View Post
      17:1 AFR is lean.
      Will do man. Maybe S300 can tell me something too.
        I guess if one had no spark they would have this problem. But going with the clicking of the boost solenoid issue first (with key ACC) i did figure out the ground wire on the map sensor is only getting 6.6V. So I re-did the fuse box ground and the fuse box is back in the OEM spot and still 6.6V.
        So...... have to figure out why i'm not getting 12V ground off the map sensor.
          Does anyone know why a map sensor would show 6.6V on ground and not 12V?
            Why would a MAP have voltage on a ground? That sounds weird...normally it's grounded through the sensor ground in the ECU and then from there it's connected to the chassis ground.
            Also, the Honda ECU sends 5v to the MAP... 12v - 5v = 6 volts? If that were the case, are you using the 5v wire for your meter negative?
            YouTube Clicky!!
              i was thinking this today too. so i'm going to re-do the test from this page:
              http://www.ozhonda.com/forum/showthr...ics-Code-3-MAP
              What i really need to know is the relationship between the boost solenoid and the MAP sensor. So far everything points to the map sensor not working:
                What did you figure out the last time your boost solenoid did that? My memory is all over the place.
                YouTube Clicky!!
                  Map sensor plug was unplugged on the throttle body.
                  While I had this plug unplugged to clean the IACV i've tripple checked it and all seems fine. So this weekend I'm going to take the IACV off again and re-do what I did. *shrugs*. Not sure what else to do. No point in even trying to start the car until i figure out what the relationship is here that is causing this problem.
                    MAP = manifold absolute pressure
                    boost solenoid is for bleeding off air on your vacation line to your waste gate to create more boost. basically, a controlled leak.
                    you have a fault in your circuit somewhere. check before and after connections on everything you just worked on with an ohm meter and looks for any indication of a problem.
                    6v on ground is a problem.
                    my guess, 5v to map sensor is shorting out to ground somehow that is showing 6v.
                    no 6v on chassis ground confirms my theory. isolate the 6v ground issue if you cannot identify the problem with a multimeter. my bet is that your resistance(indication of bad ground) is all over the place on something you just worked on. car will not run with a bad reading on map circuit
                    Originally posted by wed3k
                    im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
                      I agree, i'll chase that down. I was also sticking needles through the wire to tap into the ground. Maybe that was my issues, I'll redo this whole test.
                      As posted in my ride page, i did the following the other day:
                      - Cut and soldered the ground wire which comes from the fuse box / which is also the ECU ground. Gave it a good ground.
                      - Took the IACV off again and re-checked the connectors, wires, and such
                      - Jacked the car up and checked all other wires and connections
                      - Checked each spark plug for fire = good
                      Still the same sound with the key on ACC, which is this sound:
                      Even dipped into S300 and did some data logging. I turned off boost control which put a stop to the buzzing, but the car will still not start. It will for 1 second but a low idle. Right now i'm trying to determine if the MAP sensor should read what I'm seeing. ya....... all greek to me....
                      The shit storm..
                      Map = 30.2 ?
                      May have to let the professionals solve this one as I have no Friggin idea why the boost solenoid is making that sound or why the car will not start.
                        Have you checked your TPS? I've read a few places that the TPS could cause this.
                          FACK YA!!! No better feeling then fixing a 2 week old problem!! woooohooo!
                          So happy
                          OK, so all i had to go on was that the ground on the map sensor was not correct. So let's trace is back.
                          Pulled the map sensor inside the cabin and pulled the tape and plastic liner off to reveal this!?! ....... WTF, who's doing is this. What a mess. No wonder I can't find proper wires and .... ug. (i'm thinking this was a job I did long ago before I learned to solder )
                          So 0V when using the connector's ground and power wire..
                          But 4.7V using the wire down the line where this crimp connector is. (this is why you never use crimp connectors!!)
                          Let's fix em all.
                          Yep All better
                          As soon as I loaded the smanager config back that has boost control enabled & the solenoid didn't make a noise, I knew i had it!! Let's start the car
                          (pretty much audio only here, i forgot to bring up the graph on Smanager)
                          On another topic you see the wires cut in the first picture. These went to the ERG and two to the ESD. This makes me wonder if I even need the ESD in my setup (I have no EGR, etc.)
                            Ha! It's always the simple stuff. As usual, good troubleshooting. What the heck is an ESD? I'm drawing a complete blank.
                            Your solder job looks good too. It should considering all the practice you got.
                            YouTube Clicky!!
                              Sorry I meant to say ELD. Electronic load detector.
