nothing revolutionary gonna happen here fellas, maybe next time i will try something new but for my first build i will follow the footsteps of our predecessors.
after my f22 threw a main bearing, lost the oil pump and blew the clutch all at the same time i decided to step up to a h22a from japan star motors (bad idea)
after only a few days on the road motor locked up from a seized rod bearing. so the chance to rebuild was there.
from the bottom up, i have a pretty good idea of all the parts i will be using.
i first read the honda/acura performance book and am currently half way through maimum boost. hopefully afterward i will feel some what more confident about putting this thing back together.
everything is currently dissasembled.everything. i shipped the block off to Dan Benson for sleeves and an allign hone. i am currently in search of a good h22 crankshaft. once i find one i will also ship to him for a micro polish and balance. once back i will attempt to assemble the rotating assembly with
-9:1 CP piston and Manely rods
-ACL bearings
-Ks tuned ballance shaft elimintor kit
-and APR main studs
for the head i have started a minor polish of the exhaust ports, will post pics when finshed. also plan to use
-Skunk2 springs and tt retainers
-BC turbo cams
-Skunk2 cam gears
-APR head studs
-DNJ head gasket
-newish rockers
for fuel delivery,
-320lph AEM intank fuel pump
-AEM fuel rail
-AEM FPR
-Grams 1000cc injectors
for ignition all i know so far is that i need to start with colder then oem plugs. as far as the rest of the system i have read that the stock igniton is only good for ranges of about 10lbs of boost so i may have to upgade
and for the fun stuff,
-ramhorn deisgn mainifold from go-autoworks with 44mm waste gate flange
-Tseries billet BB Turbonetics turbo with T3 .85 a/r turbine housing with 65mm turbine wheel with T04S compressor housing with the HPC61 wheel
-44mm Tial waste gate
-Garrett bar and plate FMIC with 2.5" pipnig
-Tial BOV
-triple core half sized radiator
-Vibratnt 3" straigh through exhaust from downpipe back
and to bring it all together a p28 mapped and tuned on v300 hondata
-AEM oil pressure gauge, fuel pressure gauge, oil temp gauge
4bar MAP sensor and a wideband o2 kit
it seems like alot of work right now so im jus trying to take one componet at a time. hopefully get the head done in the next week or two while waiting on the block to come back
stay tuned
-ACL bearings
-and APR main studs
-BC turbo cams
-Skunk2 cam gears
-APR head studs
-DNJ head gasket
-newish rockers
for fuel delivery,
-AEM fuel rail
-AEM FPR
-Tial BOV
stay tuned
