Like Deev, I'm not one to be intellectual in this but I am in fact building my CB that has sat for over a year since I bought it with a blown motor.
I purchased M.I.D. sleeves, Bisimoto Rod/Piston combo and bearing kit, and a Kaizenspeed oil pump and balance shaft eliminator kit combo. I plan to bring it up to the local performance machine shop. Now before I go make an ass out of myself up there, I was wondering about the whole balancing of the crankshaft. I've read that you only need the crank, and I've also read where they will balance your rotational mass, crank w/pistons, clutch, flywheel, etc. Which would be the correct way to do this as well as being cost efficient? I'm thinking if the crank is balanced and everything else is new, then it should be fairly balanced. My only reason for asking is because I might have to go buy more parts before I go to the machine shop.
My goal for my build long term is to build an F to hold 300-400whp boosted. Right now I just want to build the bottom end and get the car running with the stock head (slight tune due to the bump in compression from Bisimoto pistons/rods) so that I can drive it. I figure once the bottom is done I shouldn't have to pull it again.
I made the thread in here because I'm not trying to filter through 30 posts of "good luck with build" and "sounds good" comments.
