i have some dsm450cc injectors and some dsm1600cc injectors...same clips as stock harness do i need to do anything to the resistor box or wiring to plug them in and start using them?
bigger injectors.
I don't know if anything short of a crazy supercar comes stock with 1600cc... if that!
"bolt and go" for the 450s, yes... but not without ECU tuning. No stock ECU is going to know what to do with 450cc injectors. It'll run like shit, if it runs at all, and you may do damage.
If you're not boosted, you don't need larger injectors. More fuel does not mean more power. Quite the opposite, actually. I assume that since you're in the Forced Induction section that you know this, and that you are probably boosted (and therefore should have some sort of tunable ECU...) but it needs to be said anyway. I've seen far too many people in the past slapping big injectors in thinking it means they'll be faster, and doing damage to their engines.
well the 1600s came out of a dsm they are precision injectors..i was just asking about it so when i go to tune(if i can get the basemap to start the car) i can do it in steps and not just start out with massive injectors..and the pte's arent high impediance..i just dont want to hook them up and them not work due to the resistor box not having enough ohms pushing out of them
If the 1600s fit in a DSM, then they will fit in your car with the same minor modifications required to run the 450cc stock DSMs, I'm sure.
If the resistor box is required, I'd check the specs on it, as well as the injectors, to see if it will work. If not, bypass it... or see what was used in the DSM. The most powerful car on this site runs 1000cc injectors, so 1600 is probably overkill unless you're shooting for the crown!
The 450cc injectors should get you up to 250whp or so. Beyond that, I'd definitely upgrade. If you can get the 1600cc injectors cheap, or you already have them in your possession, you could potentially sell/trade them for something better suited to your goals (assuming you aren't gunning for over 700whp.)
Originally posted by Sordz View PostWhat turbo are you useing? That would give you an idea of what injectors would be best. And also those 1600's will probably idle like crap.
The oem fuel rail probably will not support 6400cc's of injector though, not under high duty cycle. I don't think anyways. Neither will the fpr.
And any injector that big will need a specific injector driver. I'm sure you can rig it to work, but i wouldn't even mess with that.
Youd probably want a 1:1 rising rate fuel pressure regulator if you try and use the oem rail, but I really don't think it'll keep up.
Neither will your pump. I run dual wally 255's on my race dsm, also running 1600cc injectors on e85.
Dsm rail couldn't keep up, and it was designed for turbo application..Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by brand0n327 View Postwell i know the motor will handle 8 to 900 hp lol so you never know ...the trans however will not. i bought the 1600s for 220...and itll be great if i decide to run e85 as well...it was either buy the 1600s for 220 or buy 880s for 260...i dont think i will need any more injectors
How much power are you realistically trying to make?Knowledge is power...in EVERY sense of the word
Originally posted by MRX View PostI would've gone with the 880's. The turbo you have can put out a max of 450-500whp? You would not need 1600cc's for that. That is A LOT of fuel. Even if you use E85 I'd only go to like 1000cc's since you would still be limited by the turbo. The latency (dead time and closing time) for the 1600's will not be tuning friendly. Only get as big of an injector as you need and no more. Get too big of an injector without the supporting pressure and you won't be able to atomize the fuel properly.
I know you know your shit, just curious what you thought.
Also, since you are in the thread can you comment on what kind of headroom you like to leave in the injector? ive always tried to keep injector duty cycle around 65-70%, give or take and was wondering what your thoughts are on the subject.
If this thread is not the place, would you PM me?Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
for right now i plan on running anywhere from 400 to 500 hp for a daily driver...then once i get another daily then ill start upgrading to a bigger turbo..maybe a borg warner precision or holset..im not real sure yet...im going to get rid of the aem ems i have and go with hondata..i should of bought that to begin with..
