supercharged H22
id like to see what this thing would do with bisi header.!the pics are awesome.love the engine pic and setup..any plans for fmic?
This is awesome!
It is almost certainly the cams. When VTEC is active, the duration is probably too great, so you aren't getting as much pressure in the cylinder as you could be.
Leave a comment:
Originally posted by deevergote View PostWow, so you actually managed to get the fabled 10hp per psi!
Not having buttloads of torque might actually be a good thing. If it's too much torque, it'll be too easy to break the wheels free. I had that issue with my bone-stock GTP, and that thing rarely ever worked properly as it is. I could spin through 2 out of 4 gears.
I'm impressed by the results, for sure! My H22 is only making about 180whp, I figure (minor airflow mods and a street tune), so if I were to copy your setup part for part, I might see 230whp... I'd be very pleased with that. I wonder how long the stock internals will hold up, as this is really no different than a low-psi turbo setup.
Tomorrow I am gonna get a few street vids to show. Its very 'rippy' for lack of a better term. Above 5k its pretty quick, once past that first shift its stays in its powerband. If it blows up ill build my other block
Leave a comment:
Leave a comment:
Originally posted by Function>Form View PostI think some kind of functional hood scoop/air vent would be cool.
Originally posted by 4CYLPOWER92Not bad at all. To bad on the torque though, is that tunable? I'm used to seeing supercharged or turbo'd cars that have equal torque as the horsepower.
Leave a comment:
Leave a comment:
Leave a comment:
Originally posted by Function>Form View PostAny pictures of this setup for us to drool over?
edit: besides the side view on pg.6
Leave a comment:
Leave a comment:
impressive for something not so mainstream like turbo..i agree allowing that thing to breathe better will add...i like these things cause it a test and tune.cant wait to see where it goes!
Leave a comment:
OK fellas.. before I disclose the results, some info. I did not hit 300whp, nor 10psi, which had already figured I wouldn't based on the street tune the other day. With the 4.5in pulley that is on the charger it made 4.6 psi. My N/A setup made 195.4whp.. and the boosted setup made.......
Drum roll.......
246.6whp. 51 HP gain on less than 5psi. I'm happy with the results, for now. Now I have a baseline Psi/pulley size and can make some adjustments. Next up is a header and smaller pulley, but prolly not for a little while. Tq was 170 ft/lbs @ ABOUT 7500 RPMS, a little disappointing, cams are prolly to blame, but that was the highest tq got on any pull.
Ill post the graph later. It feels like a completely different beast. Very smooth, and responsive, and traction is an issue on the street LOL.
Leave a comment:
Leave a comment:
