No traction with higher psi heh... yeah LSD is a must even more with the instant power you are going to have. Maybe some really fat front tires..
I wonder if it would be viable for a boost controller setup by gear perhaps? Maybe a manual switch so you can limit it till third gear then go full boost? A normal two stage would probably not help much if you are still breaking traction through the full band.
supercharged H22
nice i wanted to do this to my accord befor but like u said they had no kits
Leave a comment:
Not currently. Hopefully the budget allows for it before the motor goes back in. I still kick myself in the ass for not getting it a few years ago when I wasted my final drive and had to get a new trans.
Leave a comment:
That's the only downside to practically instant torque on FWD... SO easy to just break the wheels free! My GTP was like that (approximately 240hp at the crank... but probably more torque, seeing as it was a 3.8L engine.)
You don't have LSD, right?
Leave a comment:
Currently in the process of building the bottom end, to the level of aprox 12:1 compression. I say approximately because I havent actually bought the pistons yet, still looking at options as they will have to be custom. 12/12.5:1 is the goal. The smaller of the pulleys that I have should be good for 10-12psi at 8k rpms. I will do the first tune with that, and see where it gets me.
Traction is surely a problem. Even at the 246 I was at with the first pulley(4.6psi) first gear was useless and nearly second. With the smaller pulley and street tune.. I only revved to 7k, first and second was completely useless unless feathering the throttle, and 3 was slightly useable once I had some momentum.
Leave a comment:
Originally posted by deevergote View PostTraction may be a problem. But let's not make this thread about your turbo setup.
Leave a comment:
Leave a comment:
Originally posted by deevergote View PostPSI means little. 6psi from one turbo can be significantly different from 6psi from another... and certainly different form 6psi from a supercharger! A turbo with a similar flow rate to a supercharger will likely make more power, because the supercharger provides a parasitic loss. The engine is using power to make power. The turbo is spun by exhaust gas.
The difference is that the supercharger will provide boost very quickly, while the turbocharger has to spin up first... and until it does, it provides a pretty significant exhaust restriction. Modern turbos tend to spool very quickly, making the boost lag argument less viable, and thus weakening the argument for superchargers.
Still, I have a soft spot for superchargers myself. They're just cool!
And honestly, 250-ish whp is pretty good for a FWD daily driver. 300whp would be about as high as I'd care to go, and that could be done easily with a supercharger and a few more mods than cincy90h22 has now. I think for a street car, a supercharger would be a very viable solution.
My fully built H22A is supposed to make 400+whp(with my 450cc inj and 60/63;T3/T4 Garret turbo) on 205/50/16 Kuhmo Esca 4x. I hope i dont rub and can maintain traction.
Leave a comment:
Leave a comment:
Originally posted by cincy90h22 View PostWas your motor stock? I have skunk2 intake manifold, stage 2 n/a cams. You also gotta think in cfms you flow at that pressure, the same psi on two different turbos will have a different amount of cfm. You had more torque than me, due to my cams and intake manifold changing the powerband, and also the difference between linear boost of an SC and the way boost is made on a turbo setup.Last edited by tutsuo; 02-06-2013, 12:09 PM.
Leave a comment:
Originally posted by gloryaccordy View PostSupercharging is also just inherently less efficient
But on a CB, way more original.
Leave a comment:
Leave a comment:
Was your motor stock? I have skunk2 intake manifold, stage 2 n/a cams. You also gotta think in cfms you flow at that pressure, the same psi on two different turbos will have a different amount of cfm. You had more torque than me, due to my cams and intake manifold changing the powerband, and also the difference between linear boost of an SC and the way boost is made on a turbo setup.Last edited by cincy90h22; 02-05-2013, 04:28 PM.
Leave a comment:
Leave a comment:
