well i noticed that my dsm turbo smokes a little and has some start up blow by..i have a 3/8th inch fitting tapped to my oil pan but the turbo itself has a 1/2in drain is this is whats causing my blow buy.is the 3/8 fitting acting like a bottle neck which is causing oil to back up some in the turbo?
oil drain questions
I doubt the 3/8th inch fitting is the problem. 3/8th inch should be sufficient for turbo drain.
If you think there is a problem with your turbo drain, this is what I would look for:
1. is your drain fitting in the right location on your oil pan? (it should be as high as possible)
2. your drain line should be pointing DOWN. it can never go down and then back up... as it is gravity fed.
Your problem is more than likely worn out turbo seals and your turbo probably needs careful inspection and a rebuild/rebalance.
Originally posted by rexload View PostI doubt the 3/8th inch fitting is the problem. 3/8th inch should be sufficient for turbo drain.
Originally posted by rexload View Posti believe that if your turbo is smoking, then your seals are toast
maybe somebody more knowledgeable can chime in.
Originally posted by thepowderblue View PostDo you have a nice name brand turbo or a ebay turbo?
Originally posted by thepowderblue View PostWell it could be your turbo is just cheap, Does it have shaft play?. NEVER run a cheap turbo.
Originally posted by 92smokeaccord View Postlittle tiny tiny bit spins freely with my fingers.... there's no oil in the charge tubes so its only smoking on hot side like its backing up.
Originally posted by thepowderblue View PostYou do know what shaft play will do right?
Originally posted by Saidaigen8 View PostI would say its normal cause of this cold weather. Is it actually burning oil?
